08-02-2007, 7:22 PM
#1 (permalink)
Thanks: Gave 39, Got 82
Vista Usb/Networked Printer
Hi guys
running four pc's 3 with 32bit and one with 64bit vista
Great so far but cannot get printer sharing working
Main pc Coolermaster connected to usb printer and netgear router
HTPC connected to network wirelessly can see and share files
Daughters pc wirelessly again and can share files
HTPC downstairs wirelessly again and can share files
BUT HTPC/Daughters pc/Downstair HTPC require username and password to enable printer sharing
Any ideas
Tag McLaren DVD32FLR, Tag McLaren AV32R SP 192 BP 7.1EX DAB, Tag McLaren 100x5R,Tag McLaren 100x5R,Aphrodite 192 dacs with 100x3R Stand unique 390m Intel 965OT 2.67ghz core 2 Quad 4gb 677 Kingston ram 6.0tb Maxtors Vista 64bit/mymovies WHS 2.67ghz core 2 quad 4gb ram 5.0tb maxtors
12-02-2007, 12:22 PM
#2 (permalink)
Re: Visat Usb/Networked Printer
nobody had this problem
12-02-2007, 1:44 PM
#3 (permalink)
Thanks: Gave 12, Got 13
Have you shared the printer via the Printer Properties window?
Themescene H78, Yamaha Z9, Celestion speakers, Luxman Subwoofers, Toshiba HD E1, HTPC = Q6600, Asus P5Q, Nvidia 9800GT, Blu-ray/HD-DVD dirve
12-02-2007, 1:46 PM
#4 (permalink)
yes defo but it does say password required
Public folder sharing also states password required
12-02-2007, 2:01 PM
#5 (permalink)
Just tried from an WinXP machine and I can't get past the password either
12-02-2007, 2:15 PM
#6 (permalink)
Sorted.
In the 'Network and Sharing Center' you will see Printer Sharing (password required)
Just below this there is the option to turn off Password Protected Sharing.
Turn this off and your other PCs will be able to connect without passwords.
12-02-2007, 3:28 PM
#7 (permalink)
grumble your a star
how did i miss that
