Cha1ky
Outstanding Member
Skyrim threads are flying!!!
Continued from here:
http://www.avforums.com/forums/pc-gaming/1543811-elder-scrolls-5-skyrim-part-2-a.html
Last few posts:
Mod Lists and Ini Settings
Last few posts:
Depends - if you are being attacked by city guards because you committed a crime (they seem to have supernatural detective skills!), then you can just sheath your weapon and they should accept your surrender. Then you pay a fine or do some stir and your record is clean.
If its just some other random person you pee'd off then just go explore a couple of other random dungeons or mines and level up a bit, then you should be able to see them off.
Might be a glitch though, there are more than a few, but I don't remember seeing anything that broke the main plot line.
I just wandered around for hours levelling up before even going to Whiterun - it's really easy to get distracted. The main quests will always be waiting for you later.
What's the Max level?
It's definitely the guards attacking me . Must be because of the dog I killed.
If I go elsewhere and level up, will the guards keep attacking me until they arrest me?
I have put together a list of all mods I'm currently running, so if anyone is interested here is the link.
Skyrim mod list - Google Spreadsheet
I have set it out in mod type and added links to all mods over at Skyrim Nexus if you are interested in using them.
Some sample pics are here
Here you go lads who want the ini file settings
http://www.avforums.com/forums/15929809-post956.html
