Help me win a Pc v console argument
Thread Closed
Old 11-11-2009, 10:31 AM   #1
CraigofScotland's Avatar
6,837, Level: 19
Points: 6,837, Level: 19 Points: 6,837, Level: 19 Points: 6,837, Level: 19
Thanks: Gave 574, Got 440
on another forum (non gamin or av) im having a debate about pc gaming.
They say 360 is hd and my 1920x1200 dont mean poop.
Need supportable facts!!!!!!
HALPS ME!!!
(console fanboys please go back to your caves )
Houghsx (11-11-2009)
Old 11-11-2009, 10:41 AM   #2
Jay Jay is offline
53,744, Level: 56
Points: 53,744, Level: 56 Points: 53,744, Level: 56 Points: 53,744, Level: 56
Thanks: Gave 3,691, Got 2,325
Re: Help me win a Pc v console argument
A fact...Hmm
The 360 is so powerful that it can run call of duty at 600p with no aa and can't even manage to keep a rock solid 60fps.
To be honest if someone honestly thinks a console is more powerful than a gaming pc, they are deluded, there's no point even trying to get through to them.
It'll be like taking to a brick wall.
What is better about consoles is the plug and play nature of it, but that's about it.
CraigofScotland (11-11-2009)
Old 11-11-2009, 10:49 AM   #3
insomniak123's Avatar
5,847, Level: 18
Points: 5,847, Level: 18 Points: 5,847, Level: 18 Points: 5,847, Level: 18
Thanks: Gave 58, Got 378
tell them that they're wrong, and leave.
there's no point trying to explain "HD" to console fan*boys or any non-AV enthusiasts really, as the fact remains that PC's were capable of doing "HD" far and long before anyone decided it should be a marketing ploy
anyway, for arguments sake, the majority of 360 games are indeed "HD", or 1280x720 pixels, which equals 921,600 total pixels onscreen
your measly 1920x1200 display seemingly breaks through the barrier of being "FullHD"!! (how can this be possible?! FULL! HD! ) and renders a measly 2,304,000, which as you can quite happily point out to them, is exactly 2 and a half times more detail
Ask them if they know what jaggies are, coz you haven't the foggiest
*missed this vital word...
Old 11-11-2009, 11:07 AM   #4
6,837, Level: 19
Isnt the 360 1080??
Old 11-11-2009, 11:10 AM   #5
Jay Jay is offline
53,744, Level: 56
Originally Posted by CraigofScotland View Post
Isnt the 360 1080??
No.
You can select to have it upscale to 1080p.
Even the dashbaord (nxe) isn't native 720p and upscaled 1080p on it don't look great.
The ps3 is native 1080p on the xmb though.
Both consoles generally upscale.
The ps3 has more native 1080p games than the 360.
Old 11-11-2009, 12:58 PM   #6
Houghsx's Avatar
10,576, Level: 24
Points: 10,576, Level: 24 Points: 10,576, Level: 24 Points: 10,576, Level: 24
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 729, Got 436
Cheers Craig you just gave me a right giggle at that, some people
Old 11-11-2009, 1:14 PM   #7
Illustrious Member
Rasczak's Avatar
57,924, Level: 58
Points: 57,924, Level: 58 Points: 57,924, Level: 58 Points: 57,924, Level: 58
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
Thanks: Gave 689, Got 902
The easiest thing to compare it to is a DVD player. Most DVD players will upscale the 480i or 576i material on the DVD-Video upto 1080p. But that doesn't make the video look as good as a Blu-ray (which you would expect to be native 1080p). It adds very little other than ensure a 1:1 pixel match with the screen. The vast majority of AAA Xbox 360 games are rendered in sub-HD resolutions and are merely upscaled thus - by contrast a PC is rendering at the chosen resolution.
Ultimately, and I'm sure CAS FAN will disagree, consoles are cut down PCs. The advantage is they are cheap. The disadvantages are you are told how to play (i.e. with what controller), effectively pay a tribune for every game you buy, are limited in your choices (i.e. mods, downloadable content, handling save games/profiles) etc etc.
Old 11-11-2009, 2:43 PM   #8
Jay Jay is offline
53,744, Level: 56
I know, it wasn't a positive thing.
I simply answered Craig has I got the impression he thought the 360 was native 1080p.
You could upscale halo 3 to 1080p and as you say it won't be like playing 1080p on the pc.
Old 11-11-2009, 2:53 PM   #9
PAPPACLART's Avatar
2,019, Level: 10
Points: 2,019, Level: 10 Points: 2,019, Level: 10 Points: 2,019, Level: 10
Thanks: Gave 7, Got 23
360 + PS3 not so high Def!!
Not so High Definition | DigitalFoundry
Old 11-11-2009, 4:06 PM   #10
Geege's Avatar
7,728, Level: 20
Points: 7,728, Level: 20 Points: 7,728, Level: 20 Points: 7,728, Level: 20
Thanks: Gave 252, Got 240
I am always wondering because of this debate whether or not to buy a particular game on PS3 or to get it on Windows PC (I have both a mid-high end gaming machine with 1920x1200 24inch monitor and a PS3 with a 32inch LCD). I know some games from reading reviews are better on console than PC (such as Alone in the Dark) and othe are better on PC, however it can be confusing at times to know what version to spend your money on.
Old 11-11-2009, 4:12 PM   #11
10,536, Level: 24
Points: 10,536, Level: 24 Points: 10,536, Level: 24 Points: 10,536, Level: 24
Activity: 9.5%
Activity: 9.5% Activity: 9.5% Activity: 9.5%
Thanks: Gave 63, Got 228
for any games which have a good multiplayer angle i always buy on my xbox360 (MW2 for example).
This is basically because of my set up - PC upstairs and hence i dont use that when kids are in bed etc.
xbox plugged into TV - happy days when kids are in bed.
There is nothing wrong with the xbox 360- i would go as far as saying that its the best console that has ever been released (and i have played and owned most of them)
Old 11-11-2009, 4:12 PM   #12
5,847, Level: 18
the fact remains that if you've got the hardware for it, PC will always give you the best picture
consoles are limited to what a limited set of pre-determined hardware can do, and always will be; pc's are limited only by the size of your wallet
Old 11-11-2009, 4:13 PM   #13
Gordon B's Avatar
7,607, Level: 20
Points: 7,607, Level: 20 Points: 7,607, Level: 20 Points: 7,607, Level: 20
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 227, Got 732
No no no.
Chaos (13-11-2009)
Thread Closed
Powered by
 Latest popular product prices
World of Warcraft: Cataclysm
10 prices from
 £11.51 Click to show/hide the offers
The Witcher 2: Assassins Of Kings
7 prices from
 £12.95 Click to show/hide the offers
Total War: Shogun 2
3 prices from
 £12.08 Click to show/hide the offers
Star Wars: The Old Republic - Co...
1 price
 £15.88 Click to show/hide the offers
FIFA Manager 12
5 prices from
 £14.95 Click to show/hide the offers
7 prices from
Football Manager 2012
11 prices from
Total War: Shogun 2 - Fall of th...
4 prices from
 £15.99 Click to show/hide the offers
 Updated February 12th at 10:30pm. Prices include delivery.
