Go Back   AVForums.com > Gaming > PC Games
Today's price checkPowered by
The Sims 3
Empire Total War: Special Forces Edition
Crysis: Maximum Edition
Microsoft Flight Simulator X Deluxe Edition
The Sims 3
Microsoft Flight Simulator X Deluxe E...
Batman: Arkham Asylum
Left 4 Dead
Football Manager 2009
Monsters vs. Aliens
Warcraft 3 The Frozen Throne
Crysis
 More...Prices updated November 24th at 10:30pm and include delivery.
Stock in Game, Cardiff - plus, Game component lead question ... Sword Wii 8 20-12-2006 1:02 PM
Game 5 Game Pack Conundrum. Mail to Game Nick_H Xbox 360 13 27-11-2005 1:55 PM
Old 29-09-2008, 10:35 AM   #1 (permalink)
Illustrious Member
Razor's Avatar
Thanks: Gave 890, Got 1,687
Arrow Using a Game Pad with a PC
There have been allot of threads started asking the same question. Can you play on the pc with a pad?
The simple answer is YES you can.
Allot of new games come with 360 pad support as standard and its just a matter of plug and play.
However there are allot of new and old games which don't have any pad support at all.
There is a simple solution to this problem and its with an excellent little program called Pinnacle Game profiler
Pinnacle basically maps the commands from the keyboard and mouse to your chosen pad. All types of pads are supported with the favourite being the 360 and Playstation style pad. Steering wheels can also be used with pinnacle for games that don't support wheels.
There is a 1 months free trial so you can see if you like this app after that there is a small one off fee of $19.95 (approx £14). Pinnacle is regularly updated for new games and there is a forum where you can request profiles for any game you wish if you find out it hasn't yet been supported by pinnacle. The owners of pinnacle run this forum and support it really well. I have been using Pinnacle Game Profiler for over 4 years now and I can't recommend the service enough. The program works a treat and the support is second to none. In all the time I have used this program I have never had any problems with Pinnacle, it has worked flawlessly.
A lot of die hard pc gamers turn their nose up at using a pad on the pc as the keyboard and mouse method is so accurate. However there is a need for pad support as a lot of people now have a PC or HTPC in the lounge and using a keyboard and mouse just isn't as comfortable as sitting back in a sofa with a pad a bit like a console owner would.
The most popular way of using a pad at a distance away from your pc is with a wireless 360 pad. If you want to go the wireless route with a 360 pad you will need the following.
360 Pad
Play.com (UK) : Official Xbox 360 Wireless Controller : Xbox 360 - Free Delivery
Crossfire Wireless Gaming Receiver
Play.com (UK) : Microsoft Xbox 360 Crossfire Wireless Gaming Receiver for Windows : PC Games - Free Delivery
Simply plug the Crossfire Wireless Gaming Receiver into your pc and press the button on top of the receiver. Now switch on your 360 Pad by pushing the guide button and now sync your 360 pad by pressing the small white button on the top end of the pad. The green light will flash on the pad and then settle at one of the four positions. Your pad is now sync'd to the pc and ready to go.
If you do not have any need for a wireless pad then the normal wired 360 pad will also work with the pc and no Crossfire Receiver is needed. The wired 360 pad plug into any of your pc's USB ports and is ready to go straight away. If the 360 pad isn't your favourite design of Gamepad then there are a fair few other makes and designs of Gamepads which are all compatible with Pinnacle Game profiler.
Other Gaming Peripherals which can be used with the Crossfire Wireless Gaming Receiver
You can also use the Crossfire Wireless Gaming Receiver with the 360 Wheel and headset as shown below.
Steering Wheel
Play.com (UK) : Official Xbox 360 Wireless Steering Wheel with Force Feedback : Xbox 360 - Free Delivery
Wireless Headset
Play.com (UK) : Official Xbox 360 Wireless Headset : Xbox 360 - Free Delivery
Wired headset
Play.com (UK) : Official Xbox 360 Wired Headset : Xbox 360 - Free Delivery
How to use Pinnacle Game profiler
This little app is very easy to use.
Make sure your pad or wheel is plugged in or connected to your pc. Launch Pinnacle Game profiler and it will automatically scan your Hard Drive for known games.
It will then update its profiles for each game and present you with a list of your games.
Now select the game you wish to play by double clicking on the icon for that game and Pinnacle Game profiler will now launch the game with pad control.
To access the Pinnacle Help menu, simply press the F1 key on your keyboard while Pinnacle is open. There you will find answers to many frequently asked questions.
Useful Features
- You can calibrate the pad for all your games to suit your playing style. This can be fine tuned for each game or a global setting can be applied.
- You can control windows with your pad instead of your mouse.
- You can make your own profiles for games or modify existing profiles to suit your needs ie change button positions, invert controls etc...
- You can download user profiles from the pinnacle forums and request a profile if you find a game that isn't supported by pinnacle (the admin at pinnacle will make you a profile).
Pinnacle Game profiler is compatible with Windows 2000, Windows ME, Windows XP, Windows Server 2003 & 2008 and Windows Vista.
If a pc game already has pad support pinnacle is not needed. Most new Games for Windows have built in pad support and all that is needed is a 360 Game pad be it wired or wireless.
Drivers
You dont need a driver for the 360 pad and it will work out of the box with your pc. However If you install the driver you will get info on your battery life when you push the guide button which can be helpful. The Crossfire Wireless Gaming Receiver comes with an install disc but if you have lost that or are using a wired 360 pad here is the driver you need. Just select the options you need in the link to download the driver.
Click 4 Pics
70" 1080p SXRD Pio AX4ASi-S, SkyHD, 360Elite, 360, PS3, Wii, Bose AM15, NevoSL
Watercooled Games HTPC LC17, P6T Deluxe, i7 920@4.0Ghz, DTek FuzionV2, 4870X2+EK waterblock, 64Gb SSD, 6Gb, Forte, Enermax 1250W Rev+, Zalman Reserator XT, PA120.3 - 2nd Gaming PC, 2nd HTPC, Pronto, 50PZ80
Razor is offline   Reply With Quote
blowy111 (14-10-2009), Dr Force (13-10-2009), Lee (10-04-2009), PaulieBeef (16-04-2009), SimonH (12-10-2009)
Old 29-09-2008, 8:20 PM   #2 (permalink)
Chaosx's Avatar
Thanks: Gave 38, Got 44
Re: Using a Game Pad with a PC
Cheers mate. At some point I'll have a proper good look through this and add it to the FAQ somewhere. Nice work as usual!
TV- Sony KDS55A2000
Sound - Onkyo TX-SR605 & Quad L-ite
HTPC - Abit IP35 Pro XE/Q6600@3.0Ghz/BFG Nvidia 8800GTX/4x1Gb Crucial Ballistix/Corsair Modular 620W/Thermalright Ultra Extreme/Akasa Eclipse/Logitech diNovo & Revolution
Chaosx is offline   Reply With Quote
Old 08-10-2008, 11:45 AM   #3 (permalink)
LFC_SL's Avatar
Thanks: Gave 972, Got 1,856
If you have the wired 360 controller, I use this driver in preference to the official Microsoft one:
Xbcd 360 Install Guide
Works fine playing Pro Evolution Soccer and Flatout
Opinions expressed here are my own and do not represent those of the AV Forums or its associated websites
Selling my Aluminium Macbook | Trading Rules - Read for Your Protection | DVDs
LFC_SL is offline   Reply With Quote
Old 10-10-2008, 11:29 AM   #4 (permalink)
Thanks: Gave 2, Got 0
I've got the BigBen wired Xbox 360 pad and have tried following the above guide for installing XBCD.
However in Device Manager the controller is recognised differently by Windows XP than the Microsoft 360 pad and when following the 'update driver' section of the guide there is no choice of XBCD drivers to select from (where 2 choices are shown in the guide..).
Consequently when you open XBCD control panel there is no device recognised by the software to be able to configure.
Has anybody got this pad working with XBCD, or alternatively used any other software that can configure this pad in XP..?
Having said all the above, the pad is seen ok in the 'Game Controllers' section in control panel and works fine in Lego Batman (with the sticks and buttons correctly assigned automatically..bonus..!) but I would like to get the rumble feature working in games that support it...
Any ideas welcome...
PhilYerBoots is offline   Reply With Quote
Old 11-10-2008, 4:18 PM   #5 (permalink)
Thanks: Gave 5, Got 17
As above, I have exactly the same problem..
Music: Meridian 200 / SB Duet > Musical Fidelity DM25 DAC > Tag PA20R > Tag 125Ms > B&W 605 S2
ell-ess-dee is offline   Reply With Quote
Old 12-10-2008, 12:59 PM   #6 (permalink)
Illustrious Member
Razor's Avatar
Just did a little google and it seems to be a known issue with this make of pad. If I was you I would just give up and buy an official 360 pad instead of the third party one you have now. I never have any problems with rubble on the official 360 pad.
Click 4 Pics
Old 14-10-2008, 6:24 PM   #7 (permalink)
Conspicuous Member
namuk's Avatar
Thanks: Gave 305, Got 1,142
rubble ?? in vista never new it was supported or even the pad did it
i have the wired version
http://www.play.com/PC/PCs/4-/842412...s/Product.html
Onkyo TXSR875B,BD30,XE1,Tannoy rC,Monolith-DF/Auralex GRAMMA
X38-DQ6,Intel Q6600 3.2 Ghz,4gb Ocz Reaper,GTX 280,Prelude xfi,1TB RE3,1TB Black,RE2 500GB,2X Raptors,Vista Ultimate/Win7,Enermax 1000 DXX, Alphacool LCD External,Stacker 830.
namuk is offline   Reply With Quote
Old 15-10-2008, 8:09 AM   #8 (permalink)
Illustrious Member
Razor's Avatar
Play.com (UK) : Microsoft XBox 360 Controller For Windows : Computing - Free Delivery
Quiet a few games have the rumble feature. If you have crysis try it with the pad as it supports rumble.
Click 4 Pics
Old 15-10-2008, 2:16 PM   #9 (permalink)
Conspicuous Member
namuk's Avatar
crysis on a pad will try that.. yea i did look for supported games only thing i found was if it says "games for windows" on box then the viberation is supported
but i do have this and get no rumble
Play.com (UK) : Lego Indiana Jones: The Original Adventures : PC Games - Free Delivery
Old 15-10-2008, 2:26 PM   #10 (permalink)
Illustrious Member
Razor's Avatar
The games for windows bit sounds right to me as the 360 pad is supported out of the box.
I have Lego Batman and that has vibration, you have to switch it on in the game options.
Are you using the USB or wireless pad? If its USB maybe unplugging it and plugging it back in will sort it out.
Click 4 Pics
Old 15-10-2008, 2:37 PM   #11 (permalink)
Conspicuous Member
namuk's Avatar
i have that batman comeing . yea i have the wired one i left it plugged in yesterday and run windows update there is a updated driver/patch for the pad .
i will try the lego indiana again but i never saw vibration in settings last time but it was a quick setup . the usuall max res, max all everything play game switich of nowing you can max that game NOW next one
Old 15-10-2008, 2:40 PM   #12 (permalink)
Illustrious Member
Razor's Avatar
Let us know how you get on.
Click 4 Pics
Old 15-10-2008, 7:16 PM   #13 (permalink)
Conspicuous Member
namuk's Avatar
tryed it mate no rummble setting in controls odd with it being a pritty new game . even looked for a patch/mod nothing.. ah no worrys
Old 18-10-2008, 8:30 AM   #14 (permalink)
Thanks: Gave 2, Got 12
you can also use a PS3 sixaxis pad on pc works great with a little tweak
supersub40 is offline   Reply With Quote
Old 18-10-2008, 12:29 PM   #15 (permalink)
Conspicuous Member
namuk's Avatar
i have the ps3 pad and a adator and for the life of me i could not get it to run on vista i even messed with the software i got the adaptor to link up but could not get it to showup the pad found out later that vista had taken some support out
game, pad
