07-07-2009, 8:09 PM
#1 (permalink)
| | New Member
Thanks: Gave 26, Got 0 | maximum gaming performance out of pc
Hi, I am new to the forum and relatively new to PC gaming and I am looking to get the most out of my old system while gaming.
My pc is not exactly a gaming pc, it is used for everyday tasks such as web browsing, multimedia, office and occasionally gaming.
When gaming I keep all the graphic settings to low including the display to 640 x 480 to prevent lag
What can I do to improve the gaming performance without upgrading my components?
I was thinking something along these lines:
1 - disconnect the internet, antivirus, unnecessary windows services before gaming
2 - create a new user account to be used solely for gaming
3 - finding a software to maximize the graphics output while gaming
what would you suggest I should do? Any other options available?
Chris
07-07-2009, 8:35 PM
#2 (permalink)
| | Distinguished Member
Thanks: Gave 489, Got 631 | Re: maximum gaming performance out of pc
Welcome to the forum
Razor is the forum expert on this sort of thing but it would be helpful to know your PCs specifications. What processor, memory and graphics card do you have? What operating system are you running? What is your monitors resolution? This will help us direct advice to your system. Quote: |
| I wouldn't worry about disconnecting from the internet - especially as it will probably cause you hastle if games look for it. Is certainly worth shutting down unnecessary programmes. Depending what operating system you are running there are also a myriad of tweaks you can apply: Optimisation guide for Windows XP Optimisation guide for Windows Vista
...hopefully those links providing a starting point. Google for further information/guides/tips. Quote: |
| Frankly I wouldn't bother with that. Quote: |
| Keeping your graphics drivers upto date helps and there are other things you can do - overclocking for example. But post you'll need to post your system details before people can help you further on that.
07-07-2009, 9:03 PM
#3 (permalink)
| | New Member
Thanks: Gave 26, Got 0 | Re: maximum gaming performance out of pc
thank you for the quick response
I have read the links on optimizing the performance, I will make good use of some of those tips, namely the pagingfile, i though it had to be the same as your RAM, but next time i defrag my system I will double it. thanks
My system is quite outdated:
Win XP sp3
AMD Athlon 64 3000+
1.81 GHz
2GB RAM
Nvidia 6200 512MB graphics card
My system is updated to the latest microsoft updates, directx 9, graphics/chipset drivers
I am not sure my system can overclock much, the CPU is single core, at the moment my CPU temp is 30-38c, system 40-45c, can it overclock? I have stock cooling
I have used several XP tweaking apps to optimize the system such as turning off messenger, unloading remote assistance, start up/shutdown times
thanks for your help |
07-07-2009, 9:09 PM
#4 (permalink)
| | Member
Thanks: Gave 2, Got 102 | Re: maximum gaming performance out of pc
if you have enough disk space(or 2nd drive) you could partition the drive and then install a win XP for gaming and have nothing but the essential software installed.
thats what ive done in the past
Sony Bravia 40V3000, SKY+HD, Panasonic DMR-EX77, Cambridge Audio Azur 540R, Xbox 360 Premuim & Arcade + HD-DVD, PS3 40gb & Wii - Apple Mac Mini 2.0, Apple MacBook Pro 2.4ghz, Dell Studio 15 with Bluray drive, Self build PC with Intel Q9550 & 128gb SSD
07-07-2009, 9:15 PM
#5 (permalink)
| | Senior Member
Thanks: Gave 244, Got 158 | Re: maximum gaming performance out of pc Quote:
Originally Posted by Boon72 if you have enough disk space(or 2nd drive) you could partition the drive and then install a win XP for gaming and have nothing but the essential software installed.
thats what ive done in the past  | Ive always wondered how that works, partitioning and other installs, How'd u go about doing that? Can answer 2 in 1 if the OP wants to know aswell.
__________________ Retired
Reason: typo
07-07-2009, 9:15 PM
#6 (permalink)
| | Member
Thanks: Gave 26, Got 41 | Re: maximum gaming performance out of pc
Looking at your spec, there isn't a great deal you can do. The CPU and memory are OK, but your graphics card is the weakest point. If I remember correctly, the 512Mb version of the 6200 is actually 256Mb of card memory and 256Mb taken from your system memory. At least all the cards I saw were like that. Its a very weak graphics processor as far as gaming goes. If you want to play more games, I would recommend considering an upgrade, for just £30 or £40 you would see a huge improvement.
Its probably not worth spending more than that as you would then start to be limited by your cpu.
07-07-2009, 9:19 PM
#7 (permalink)
| | New Member
I added a second HDD 320GB for backup purposes, I did try to install a second XP for gaming a while back but I gave up on that idea as the system boots and reads the boot.ini file it wouldn't load up any of the OS installed, it would ask me to choose which OS I wanted.
As I am not the only user of the pc it would be highly annoying for the other users to be prompted with that screen everytime they started the pc.
Maybe I could modify the boot.ini file to hide the gaming XP OS and only load it when I instruct it to but I don't know how
Thanks for the help |
07-07-2009, 9:25 PM
#8 (permalink)
| | New Member
Thanks: Gave 26, Got 0 | Re: maximum gaming performance out of pc Quote:
Originally Posted by conan your graphics card is the weakest point. If I remember correctly, the 512Mb version of the 6200 is actually 256Mb of card memory and 256Mb taken from your system memory. | very good memory there
you are absolutely right it's turbocache
I wasn't aware that graphics card was so weak
To complement my CPU and RAM for £30 or £40 what kind of graphics card could I get? Wouldn't mind a pre-owned GPU
EDIT
something like this card? WORKING XPERTVISION 7600GS 256MB PCI-E GRAPHICS CARD on eBay (end time 31-Jul-09 10:20:04 BST)
Thanks for the help
Reason: GPU
07-07-2009, 10:01 PM
#10 (permalink)
| | New Member
WOW that is some card  considering the rest of my set up
according to CPU-Z my graphic interface is
PCI-Express
Link Width x16
Max supported x16
i'm slightly confused now
07-07-2009, 10:08 PM
#11 (permalink)
| | Member
No worries, you have a PCI express slot  You can get a PCI express version of the card also, they will probably be cheaper |
07-07-2009, 10:17 PM
#12 (permalink)
| | New Member
Thank you
I do like that card and PLAY does free delivery which is great
I fear now I might get too excited with the upgrading and not stop at the GPU but there's not much else I can realistically upgrade as my system uses the outdated DDR as opposed to DDR2, any other upgrades would create bottlenecks I guess, better control myself
Thanks for the help
EDIT:
I must say I am very impressed with the feedback received and as of now the forum is on my permanent bookmarks
Reason: FORUM help quality
08-07-2009, 8:23 AM
#13 (permalink)
| | Senior Member
Thanks: Gave 98, Got 78 | Re: maximum gaming performance out of pc
Hi buddy, glad u like the forum. its great place for any advice!!!
You should consider perhaps updating your RAM, its cheap to do after your GFX card. memorybits is where you wil get good and cheap ram, including gaming ram  2/3 gig of something with faster speed, you will notice a huuge difference. (prosuming i read you right and only have ddr)
Also, have a look in the classified section of the forums .. people always seeling parts from an old pc etc also make a wanted thread with what you need, how much you can pay etc and see if anyone can come up with the good. Very relaible place to use, as I do weekly now.
That GFX card should suit a higher res than the one you first stated, so you should enjoy it. Also consider ebuyers as a good place for computer parts/electronics on a budget.
Welcome to PC gaming.
__________________ One day I might downgrade my games so they can play on a console | |
08-07-2009, 9:45 AM
#14 (permalink)
| | Veteran Member
Thanks: Gave 480, Got 425 | Re: maximum gaming performance out of pc Quote:
Originally Posted by 1mp0551b13 | Stick a wanted ad up in the classafieds as you will probrably save yourself a fair amount and most likely a better card for that money.
Xigmatek Midgard | GA-X38-DS4 | Q9400 | Asus 1GB 4870 | 4GB HyperX 1066MHz | X-Fi Xtreme Gamer | 500GB Samsung F1 | Tagan BZ 800W | Skythe Mugen 2 | 360 Elite "Finishing second means your the first person to lose" - Jilles Villeneuve |
08-07-2009, 10:03 AM
#15 (permalink)
| | Prominent Member
Thanks: Gave 307, Got 399 | Re: maximum gaming performance out of pc
Yeah I've got a 7600GS in my old computer... it doesn't do that well with modern games now. Try for something a bit newer.
JVC DLA-HD100 | Pioneer KRP-600M | Samsung PS42Q97HDX | DVDO EDGE | Gaming HTPC (Q9550 @ 4GHz + HD4870 X2) | Toshiba EP30 HD-DVD | Sky HD (Samsung HD) | Michell Gyrodec SE + Trichord Diablo | Moon CD5.3 RS | XBox 360 | PS3 | Audiolab 8000AP/X7 | B&W CDM-NT surround speakers
