Lava through glass
Old 11-09-2009, 4:06 PM   #1
Zombane's Avatar
6,384, Level: 19
Points: 6,384, Level: 19 Points: 6,384, Level: 19 Points: 6,384, Level: 19
Thanks: Gave 285, Got 240
Lava through glass
exif should be included, can provide if not.
My picture is of a Lava Lamp. I think the reflections of the "lava", the light and glass make a really interesting image. Nothing other than a re-sizing done in PS, so is au natural!
Not as sharp as I'd hoped, but I'm still a newbie!
Comments welcome.
Old 11-09-2009, 5:17 PM   #2
pixelpidgeon's Avatar
6,577, Level: 19
Points: 6,577, Level: 19 Points: 6,577, Level: 19 Points: 6,577, Level: 19
Thanks: Gave 349, Got 210
Re: Lava through glass
nice. very floyd is the line running half way down on the left side coming from behind the lamp?
Old 11-09-2009, 5:29 PM   #3
Zombane's Avatar
6,384, Level: 19
Not sure tbh, I think it's some kind of reflection from the window.
I was going to retake it, but I think coupled with the curve of the glass on the right hand side, it shows the "glass".
Old 11-09-2009, 7:14 PM   #4
Butch499's Avatar
4,431, Level: 15
Points: 4,431, Level: 15 Points: 4,431, Level: 15 Points: 4,431, Level: 15
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 403, Got 175
Interesting photo here, I like the colours. The small bubbles are in the glass, right? To be honest though, I think I would have pulled back a touch and then persisted, trying to get a crisper shot to enter with.
Old 11-09-2009, 7:23 PM   #5
Zombane's Avatar
6,384, Level: 19
The bubbles are in the fluid, as I shook it first!
Old 12-09-2009, 8:19 AM   #6
6,374, Level: 19
Points: 6,374, Level: 19 Points: 6,374, Level: 19 Points: 6,374, Level: 19
Thanks: Gave 151, Got 283
Nice idea, like the bubbles and colours. I suspect you are going to loose definition as you are shooting through the glass and "liquid", but it's maybe not as crisp / sharp as it should be.
Ian.
Old 12-09-2009, 2:26 PM   #7
Zombane's Avatar
6,384, Level: 19
Ian.
I was in two minds as to whether the softness improves the image, or if it would've been better if it was sharper and more defined.
Old 27-09-2009, 3:08 PM   #8
electrolyte's Avatar
15,343, Level: 29
Points: 15,343, Level: 29 Points: 15,343, Level: 29 Points: 15,343, Level: 29
Thanks: Gave 1,456, Got 1,030
I like this one too. I think a sharper image would have worked even better though.
Old 28-09-2009, 2:13 PM   #9
4,693, Level: 16
Points: 4,693, Level: 16 Points: 4,693, Level: 16 Points: 4,693, Level: 16
Thanks: Gave 59, Got 103
Sharper would have been better - otherwise a bit too fuzzy for me. Are you AF on the glass or did you try and MF onto the big blob in the middle?
