Glass by candlelight
Old 05-09-2009, 6:50 PM   #1
1,552, Level: 9
Points: 1,552, Level: 9 Points: 1,552, Level: 9 Points: 1,552, Level: 9
Thanks: Gave 147, Got 16
Set this up after playing with a few positions. It's a black background with the 2 objects on a mirror.
Nikon D300
2.5sec
f/32
ISO 800
48mm
If the exif's missing, I can email the original.
Old 05-09-2009, 7:38 PM   #2
bodoman's Avatar
13,445, Level: 27
Points: 13,445, Level: 27 Points: 13,445, Level: 27 Points: 13,445, Level: 27
Thanks: Gave 1,165, Got 1,306
Re: Glass by candlelight
I dont know why i like this photograph, but i certainly do
Old 05-09-2009, 10:41 PM   #3
10,453, Level: 24
Points: 10,453, Level: 24 Points: 10,453, Level: 24 Points: 10,453, Level: 24
Activity: 14.8%
Activity: 14.8% Activity: 14.8% Activity: 14.8%
Thanks: Gave 89, Got 262
I love the soft light the candle is casting on the bowl to the left, but for me the candle flame itself is a little too harsh for the rest of the picture, and it would have been nicer if the bowl and its reflection were more vertical.
Old 05-09-2009, 10:46 PM   #4
Butch499's Avatar
4,431, Level: 15
Points: 4,431, Level: 15 Points: 4,431, Level: 15 Points: 4,431, Level: 15
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 403, Got 175
Yes I would agree that the image is well lit, and could work even better with a slightly rearranged composition. It's a good entry though!
Old 12-09-2009, 8:13 AM   #5
6,374, Level: 19
Points: 6,374, Level: 19 Points: 6,374, Level: 19 Points: 6,374, Level: 19
Thanks: Gave 151, Got 283
Good effort and well lit. Like how you know they are resting on something, but you just can't see it, and they appear to be floating in the air. Agree about the glass bowl looking at an angle.
Ian.
Old 24-09-2009, 8:42 PM   #6
johnaalex's Avatar
22,591, Level: 36
Points: 22,591, Level: 36 Points: 22,591, Level: 36 Points: 22,591, Level: 36
Activity: 8.7%
Activity: 8.7% Activity: 8.7% Activity: 8.7%
Thanks: Gave 560, Got 1,186
Very nice shot and I like the fact you used the smokey glass to add another texture
Old 27-09-2009, 2:49 PM   #7
electrolyte's Avatar
15,316, Level: 29
Points: 15,316, Level: 29 Points: 15,316, Level: 29 Points: 15,316, Level: 29
Thanks: Gave 1,458, Got 1,030
I agree, this is almost lovely - the flame is a bit harsh and the sloping glass is a bit off-putting.
Old 28-09-2009, 2:55 PM   #8
4,693, Level: 16
Points: 4,693, Level: 16 Points: 4,693, Level: 16 Points: 4,693, Level: 16
Thanks: Gave 59, Got 103
I think this would work better with either one or the other, but both together is trying to capture too much in what could be an exquisitely simple and well judged shot.
