RGB cable for Modded ntsc cube where?
Old 24-09-2003, 2:29 PM   #1
mandmac
Posts: n/a
I've used s-video for nearly 2 years with my JAP modded cube but a forced upgrade to a Sony kd32-dx40 has stuffed that up.
S-video is bad, colour bleed and less defined than on my old set, so after already replacing the set twice I cant be bothered looking for one with good s-video.
The rgb on the tv is superb so where do you find a good cable that enables my cube to output rgb,I know these arent available in shops and are mainly made by enthusiasts.
Does anyone make them or know where to find one, a hint at what price these fetch would also be helpfull.
Old 24-09-2003, 4:31 PM   #2
3,671, Level: 14
Points: 3,671, Level: 14 Points: 3,671, Level: 14 Points: 3,671, Level: 14
Thanks: Gave 59, Got 56
Try lik-sang and Goblin.
Gary
Old 24-09-2003, 4:43 PM   #3
phenom2003
Posts: n/a
Groundy, where are you?
Old 24-09-2003, 4:47 PM   #4
mandmac
Posts: n/a
lik sang dont sell them anymore, complaints about quality or something.
Old 25-09-2003, 10:45 PM   #5
6,590, Level: 19
Points: 6,590, Level: 19 Points: 6,590, Level: 19 Points: 6,590, Level: 19
London Console are doing them for £45.
Old 26-09-2003, 5:33 AM   #6
7,242, Level: 20
Points: 7,242, Level: 20 Points: 7,242, Level: 20 Points: 7,242, Level: 20
Thanks: Gave 3, Got 0
CAgames do one and i would really recommend it. There website is www.cagames.co.uk and they will offer you next day delivery.
Old 26-09-2003, 10:01 PM   #7
wod wod is offline
6,271, Level: 18
Points: 6,271, Level: 18 Points: 6,271, Level: 18 Points: 6,271, Level: 18
Thanks: Gave 1, Got 4
contact saurian at londonconsoles to see if hes doing them again as he did before for 45 quid
