Gamecube AV Connections Help!
Old 15-02-2002, 4:59 PM   #1
Big Jim
Posts: n/a
Smile Gamecube AV Connections Help!
My campaign has worked and I am getting a Gamecube for my birthday from the wife when a mate goes to Japan in March.
I have no probs on where to get it chipped etc. BUT I have an old 50hz panny TV which will not display NTSC.
so I need some options. Help!
What is the Digital video cable? I don't suppose it is anything useful like RGBHV or DVI?
Is there a Component to RGB converter yet? I know John Sim was working on one, is there an eta?
Anyone doing an RGB mod yet?
If all else fails can anyone reccomend a decent (and cheap) NTSC to PAL box or VGA box?
Old 18-02-2002, 3:07 PM   #2
stewarthollyhead
Posts: n/a
Firstly why wait for your friend to get it, import it now. www.lik-sang.com is where i got mine from cheaply.
2nd for your inputs try:
Below is the product description. It costs £30 and knowing li-sand iwll be good quality.
Connect your GameCube or N64 console to a VGA monitor for a much brighter display
Auto switching between TV game or PC connection (GC and N64 can be connected at the same time)
Outputs: Speaker, VGA, AV Multi Out
Inputs: VGA, AV Multi, Sound card
For NTSC GameCube and N64 only
if you do import a console you need it chipped (mine came pre chipped from lik sang). When your ready to buy games use USA site www/cduniverse.com. fast and cheap
Old 18-02-2002, 3:10 PM   #3
ashearer's Avatar
8,070, Level: 21
Points: 8,070, Level: 21 Points: 8,070, Level: 21 Points: 8,070, Level: 21
Thanks: Gave 1, Got 1
I agree with the comments about Lik-Sang. Alternatively, try http://www.goblindirect.com/ who are excellent for US/Jap games or pre-chipped consoles. They tend to be cheaper than Lik-Sang as delivery is cheaper and you don't get stung by customs.
