AVForums.com twitter AVForums reviewers are ISF Certified.  Click for more information. AVForums is a member of CEDIA.
AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Computers > Optical Storage (CD/DVD/HD DVD/Blu-ray drives)
Notices
i want to start photography, where do i start?? which camera? taraloveslewis Digital Photography General Chat 25 16-05-2007 5:33 PM
Need help on calculating H-start,V-start,Clock,Phase in service menu Swizzer Plasma Televisions 12 17-11-2006 10:03 PM
Anyone had a recording not end automatically? zAndy1 Sky and Sky+ 7 15-06-2006 1:04 PM
Automatically rip cd in MCE martyn_wheeler Windows Media Center Edition MCE 1 29-05-2006 5:48 PM
can i set MCE to start automatically on start up ? newstuart Windows Media Center Edition MCE 9 14-06-2005 7:26 PM
Old 04-12-2008, 6:22 AM   #1 (permalink)
why won't my dvd-rw start automatically?
I insert a CD and I get nothing.....at least on some CD's.
What can I do to make my CD's run as soon as I insert them?
I suppose this is called "auto run". Can someone help me?
burnselk is offline   Reply With Quote
Old 04-12-2008, 10:14 PM   #2 (permalink)
avinitski's Avatar
Thanks: Gave 70, Got 155
Re: why won't my dvd-rw start automatically?
for Windows XP?
a few ways to do this.
Open Windows Explorer by pressing the Windows + "e" key.
Right-click the desired CD-ROM and select Properties from the menu.
Select the AutoPlay tab.
Select each item from the pulldown list and for the Action to perform, select "Take no action" to disable autorun, or pick the apporpriate action to take if enabling autorun.
Select OK.
or a registry tweak.
Or use TweakUI PowerToy.
Also apparently if you have turned off AutoPlay everywhere, you can still bring it up when you insert a CD–by holding down the Shift key.
If its for Vista then Auto play has its very own Control Panel section just for this. Control Panel > Auto Play.
avinitski is offline   Reply With Quote
Old 05-12-2008, 12:11 AM   #3 (permalink)
Originally Posted by avinitski View Post
for Windows XP?
Yes, Windows XP Home, and thanks. I'll let you know how it goes using your methods.
Old 22-12-2008, 1:51 PM   #4 (permalink)
run-services.msc-cdrom-auto
imohammed01 is offline   Reply With Quote
automatically, dvdrw, start
