Toshiba SD-H802a Problems
Hi Chaps,
Have recently bought the above drive so that I can back up all my HD-DVD's and play them via PC to Popcorn Hour NMT,
My PC specs are:-
AMD 4000+
Mobo: Asus A8n -SLi
2gb
XP SP 3
When I install the drive to my PC via IDE on slave, my PC just locks up and doesn't load up into windows ? As soon as I take the drive out it boots up ?
Anyone with ideas ? I am not looking to play the DVD's on the PC as I don't think that the CPU will handle it anyway.
Oh and I have also installed the UDF file reader as well,
Any help warmly appreciated.
