AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Optical Storage (CD/DVD/HD DVD/Blu-ray drives)
LinkBack Thread Tools Display Modes
Old 23-07-2007, 12:30 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Will a PC Blu Ray Burner bought in the US work in a UK PC?
I am off to the US in three weeks time and was thinking of purchasing a Blu Ray burner whilst out there for my PC.
I need it only for archiving HDV footage shot with my Canon HV20 [yet to be purchased!]. I don't actually need the drive to watch commercial blu ray films on my PC.
When I get back from the US I am going to buy this PC : - http://www.overclockers.co.uk/showpr...id=781&subcat= . Which I assume is going to be good enough to cope with the demands of both editing HDV footage and also writing it to a Blu Ray Disk?
Can anyone confirm if the US blu ray burner will work - will it be region coded? I thought that at the moment region coding is not enabled on blu ray drives?
I will need a blu ray burner no matter what so even if I don't buy it in the US I am going to have to buy one in the UK. So which one should I go for which offers a reasonable balance between price and performance.
sayso is offline
Old 23-07-2007, 12:41 PM   #2 (permalink)
Thanks: Gave 20, Got 56
Re: Will a PC Blu Ray Burner bought in the US work in a UK PC?
Burner will work no matter what region. If its anything like DVD drives, the region will be set at first use of a commercial disk. If it already comes set at source, then just get AnyDVD HD - which will remove all the DRM BS in addition to the region coding. And the same software will be sufficient if you decide to get an HD-DVD drive in the future.
sinizterguy is offline
sayso (24-07-2007)
Old 26-07-2007, 9:20 AM   #3 (permalink)
Synchro's Avatar
Thanks: Gave 93, Got 93
Agree with above comments. Which ones are you looking at?
Vista PC Specs Here99999999.Vista HTPC Specs Here
Add yours Here
Synchro is offline
Old 04-08-2007, 10:39 AM   #4 (permalink)
Hi Synchrouk - Haven't really looked at any one in particular. Just thought if i see one in the US it is bound to be cheaper than one here in the UK. Any recommendations?
sayso is offline
blu, bought, burner, ray, work
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
