11-07-2007, 9:58 PM
#16 (permalink)
Thanks: Gave 1, Got 6
Re: Pioneer BDC-202
I had a black one on order, seen the beige ones in so changed my order.
Mine has been despatched & I should recieve tommorrow-12-07-07.
Be intersting to see how this performs as I already have a HD DVD player so wanted the Blu-Ray to complete the range of films I wanted.
Ill post my findings once up & running.
Carl
12-07-2007, 6:55 AM
#17 (permalink)
Thanks: Gave 8, Got 16
Re: Pioneer BDC-202
I`m waiting for the black. Anyone seen any anywhere?
12-07-2007, 8:42 AM
#18 (permalink)
Thanks: Gave 8, Got 31
Re: Pioneer BDC-202
You don't know how close I was to buying one from Overclockers yesterday. I was watching the stock tick down during the day, until they had 1 left at about 5pm. I've got to sort out some other things before I commit to getting one though.
One issue I have is that the front of my case is all silver, and you can only get the drive in black or beige! I've even thought of spray painting the front, or putting on some silver foil. How sad is that....
Samsung PS50A656, Sony STR-DA2400ES, Samsung BD-P1500 Blu-Ray, Sony PS2, Vista Media Centre (BD/HD-DVD ready), Mission FS1 Speakers, Harmony 525 Remote Control
12-07-2007, 11:49 AM
#19 (permalink)
Thanks: Gave 93, Got 93
Re: Pioneer BDC-202
Vista PC Specs Here99999999.Vista HTPC Specs Here
Add yours Here
12-07-2007, 12:22 PM
#20 (permalink)
Re: Pioneer BDC-202
Originally Posted by Synchrouk
You may have hit the nail on the head there Synchrouk. Looks like it could do the job, although it isn't obvious whether it replaces the front bezel, or just sticks on the front.
12-07-2007, 3:11 PM
#21 (permalink)
Thanks: Gave 15, Got 38
Re: Pioneer BDC-202
They just stick on easy job, but they don't fit all drives though.
Picture of my pioneer dvd drive.
dvds
12-07-2007, 4:24 PM
#22 (permalink)
Thanks: Gave 1,355, Got 262
Re: Pioneer BDC-202
The Dabs site shows it as discontinued.
Optoma HD70 with 95" Screen|Blu Ray/HD DVD HTPC|Sky HD|Onkyo TX-SR606|Jamo A102s|120 gig XBOX 360|USA 500 gig PS3|Wii|Harmony 885
12-07-2007, 4:46 PM
#23 (permalink)
Re: Pioneer BDC-202
dvds
12-07-2007, 8:26 PM
#24 (permalink)
Re: Pioneer BDC-202
That looks pretty good. Was it easy to fit? Is the bezel aluminium or plastic? I guess if it sticks on the front, there's a chance the bezel could sit proud of the case.
12-07-2007, 9:41 PM
#25 (permalink)
Re: Pioneer BDC-202
Fairly easy the problem you may have is getting the eject button to align up apart from that very easy and yes it's made from 3mm aluminium.
Most cases have have slots for the screws so you have fine adjustment so the drive stays flush with the case front.
dvds
13-07-2007, 6:59 PM
#26 (permalink)
Thanks: Gave 23, Got 23
Re: Pioneer BDC-202
I will picking mine up in the morning
Missed the delivery man this afternoon
Orderd the beige one as it will be behind a front cover anyway.
I'll tell you all about it tomorrow
Hitatchi 42pd7200, Denon 2910,Panasonic DMR-E55, Onkyo TX-SR875, Gale series 30 speakers. Xbox 360+HD DVD add on, Samsung BD-P1400, Squeezebox Classic, MythTv HTPC
13-07-2007, 7:47 PM
#27 (permalink)
Thanks: Gave 163, Got 51
Re: Pioneer BDC-202
Looking forward to the report as I'm keen to get one!
Hitachi PJ-TX300, Yamaha HTR-5540RDS, HTPC (incl. BluRay!), Toshiba HD-A1 (format neutral!), Kef KHT2005, Paradigm PDR-10, 92" Dalite screen, Humax PVR 9200, Pioneer DV535, Archos AV560, Creative Zen Micro, Xbox 360, Original Xbox (w/XBMC), Harmony 525 Remote, Toshiba 32" LCD
13-07-2007, 8:14 PM
#28 (permalink)
Thanks: Gave 15, Got 44
Re: Pioneer BDC-202
Got mine this morning. Very pleased with it (although I only have 2 disks, Black Hawk and Ghostrider) It works flawlessly with these disks and PowerDVD 7.3. Playing Blu-rays from hard disk did not give me the option to resume from last viewing point, it does now playing from BD disk. Also if I paused playing from Hard DiskPowerDVd crashed,not so playing from BD disk. It's very quiet also using AnyDVD HD speed control. I forgot to try it with this turned off, will try it later.
What more can I say, it works and it's quiet. As it was OEM you get nothing with it, Sata cable or power adaptor.
Edit: Don't notice any extra CPU usage playing from BD disk over Hard Disk
Another Edit: Crash on pausing was not fixed by the new drive but by the latest PowerDVD patch
VW60 Black Pearl , Panasonic 37PX80B; Marantz SR4300; Monitor Audio B2s (fronts & surrounds); Monitor Audio ASW100; Monitor Audio Bronze Centre; Blu-Ray HCPC; I miss the taste of meat
14-07-2007, 9:21 AM
#29 (permalink)
Re: Pioneer BDC-202
Picked up drive this morning
Does not work !!
Pc will not boot with the drive connected at all.
A bit of looking around throws up this link on pioneer website
http://www.pioneerelectronics.com/pi...otherboard.pdf
It tells us there is a recognition problem wtih AMD’s chipset using the SB600 Southbridge, which my MOBO uses
Not a good start!
14-07-2007, 9:36 AM
#30 (permalink)
Re: Pioneer BDC-202
Does not work !!
Not a good start!
Bummer eh Batty. Wasn't aware of Pioneers compatability list. Does your mobo have the new AMD 690 chipset? I've got an older Asus A8N-VM CSM in my HTPC, and that uses the Nforce 430 chipset, so (cross-fingers) it may be ok.
Any BIOS updates for your mobo (which is it exactly by the way?)
