Help looking at amp but dont understand rms would this work
| | Post Reply |
| | #1 |
| New Member | Help looking at amp but dont understand rms would this work |
| Quote |
| | #2 |
| New Member | Re: Help looking at amp but dont understand rms would this work |
| Quote |
| | #3 |
| Quote |
| | #4 |
| Veteran Member | Re: Help looking at amp but dont understand rms would this work |
| Quote |
| | #5 |
| Moderator | Re: Help looking at amp but dont understand rms would this work |
| Quote |
| | #6 | ||||||||||||||
| New Member
Thanks: Gave 0, Got 0 Posts: 12 | Re: Help looking at amp but dont understand rms would this work | ||||||||||||||
| Quote | |||||||||||||||
| | #7 | ||||||||||||||
| Member Location: Victoria, B.C.
Thanks: Gave 11, Got 14 Posts: 125 | Re: Help looking at amp but dont understand rms would this work | ||||||||||||||
| | #8 | ||||||||||||||
| Member
Thanks: Gave 9, Got 1 Posts: 169 | Re: Help looking at amp but dont understand rms would this work | ||||||||||||||
| | #9 | ||||||||||||||
| | #10 | ||||||||||||||
| Veteran Member Location: Nottinghamshire
Thanks: Gave 953, Got 1,548 Posts: 7,238 | Re: Help looking at amp but dont understand rms would this work | ||||||||||||||
| | #11 | ||||||||||||||
| New Member
| | #12 | ||||||||||||||
| | #13 | ||||||||||||||
| New Member
| | #14 | ||||||||||||||
| Post Reply |
to be honest the speakers from all in ones are usually way below their stated wattage & certainly would not stand the power output for long. Also with the speakers being 4 ohm you run a risk of damaging the Amp. Yes you would require an independant "Active" Sub (Has it's own Amp. built in), this is connected by a phono to phono lead to the sub outlet.
E. & O.E.
LinkBack URL
About LinkBacks
