3.5 million visitors each month
Go Back   AVForums.com > Manufacturer-Specific Owners' Forums > Onkyo Owners' Forum
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Hi-Fi advice needed on new setup carlaz Hi Fi Systems and Separates 0 02-07-2007 9:04 PM
New setup, advice needed please! Willo84 Home Cinema DIY 4 22-05-2007 12:51 PM
First setup advice needed .. BobHarris AV Amplifiers and Receivers 1 08-04-2006 9:49 PM
Advice needed on DVD setup... Agent_Trig DVD Players 3 04-01-2006 12:08 PM
setup advice needed blackadder AV Amplifiers and Receivers 0 17-01-2004 2:30 PM
Old 23-07-2008, 11:50 AM   #1 (permalink)
kendisred's Avatar
7.1 setup advice needed
hi all,
i have a 7.1 speaker setup , what i want to know is ...if i watch a dolby digital dvd.. example matrix .. it shows dolby digital ex in amp display..if i press surround on remote and show pl11x movie would this create 7.1 even though the disc is dolby digital ..any advice would be helpful
kendisred is offline   Reply With Quote
Old 23-07-2008, 12:21 PM   #2 (permalink)
Thanks: Gave 9, Got 13
Re: 7.1 setup advice needed
Yes it would! It's the 'x' in PLIIx which tells you that it's formatted or matrixed to 7.1. PLIIx is for 7.1 only, 5.1 would only show up as PLII, and as it's a Dolby format, it'll work perfectly!
sb09 is offline   Reply With Quote
Old 23-07-2008, 1:58 PM   #3 (permalink)
kendisred's Avatar
cheers thanx for that
Old 23-07-2008, 2:37 PM   #4 (permalink)
No worries. You won't get 7.1 discrete channels, you'll get 5.1 discrete with two added matrixed channels to the rears, though your first post seems to suggest you were already getting 6.1 discrete if Dolby Digital Ex was showing on the amp.
This means the same discrete rear channel audio will be played through both rear speakers taking it from 6.1 to 7.1. Currently at work, so can't see (and can't remember) what audio formats are available on the Matrix.
Old 25-07-2008, 11:02 AM   #5 (permalink)
Thanks: Gave 2, Got 35
Dolby Digital Ex is not discrete 6.1. Only DTS brought out a fully discrete 6.1 mix called DTS discrete 6.1!
Both Dolby and DTS had rival matrixed 6.1 mixes called
Dolby Digital EX (6.1) and DTS-ES (6.1).
These still exist for standard DVD, but of course High Def video has enabled the use of 6.1 and 7.1 discrete channels.
missinglink is offline   Reply With Quote
Old 25-07-2008, 11:23 AM   #6 (permalink)
missinglink,
Many thanks for tidying up/correcting what I was trying to say to kendisred above.
advice, needed, setup
