Firstly I am connecting my 606 to a set of 5 Tannoy CMS401E ceiling speakers. I'm totally confused about how to set the speakers, the Tannoy website says in the manual (
http://www.tannoy-speakers.com/produ...401-manual.pdf)
"Use the rotary switch located on the front of the unit to select whether you wish to use
the speaker in a low-impedance or distributed-line application.
3
THE SPEAKER IS SUPPLIED IN LOW IMPEDANCE MODE. NEVER CONNECT THE
SPEAKER TO A 70/100 VOLT AMPLIFIER WHILE IT IS SET FOR LOW IMPEDANCE.
All CMS401e and CMS401 DCe models use a 30W transformer. When using distributedline
systems, the transformer can be tapped at 30W, 15W and 7.5W, with an additional
3.75W tapping for 70.7V line systems."
So what do I set the speakers to for this amp?
Also can I use banana plugs to connect the 606 to the speakers?
