AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Manufacturer-Specific Forums > Onkyo Products
Home Cinema Podcast
Thu, 5 Aug 2010
Play Home Cinema Podcast : 5th August 2010
We discuss 3DTV evolution, 3D projection and HDMI distribution.
 Duration 1:13:39
Latest AVForums Hardware Reviews
AVFoundry VideoEQ Pro ReviewSamsung C750 (LE40C750)  ReviewPanasonic VT20 (TX-P65VT20B) ReviewAcoustic Energy Aegis Neo V2 Series Review
Movies Podcast
Tue, 31 Aug 2010
Play AVForums Movies Podcast : 31st Aug 2010
We discuss Escape from New York, The Evil Dead and more...
 Duration 0:58:04
Latest AVForums Movie Reviews
Four Lions Blu-ray ReviewBreathless 50th Anniversary Edition Blu-ray ReviewCemetery Junction Blu-ray ReviewForbidden Planet Blu-ray ReviewKick-Ass Blu-ray ReviewShutter Island Blu-ray Review
LinkBack Thread Tools
Old 08-02-2010, 1:58 PM   #1
Thanks: Gave 2, Got 0
Exclamation Processing options on Onkyo amp. Please help.
Im trying to setup the inputs on my Onkyo amp. Now it gives me a LOAD of options for each input.
Which processing option is best to choose for blu ray and xbox 360 and 5.1 speakers?
Puresound, THX, dolby, DTS etc etc etc.
Please tell me what you set yours to and why.
Thanks for any advice.
PhenomenalFox is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on Twitter
Old 08-02-2010, 3:04 PM   #2
Thanks: Gave 345, Got 1,433
This really is a matter of taste.
It varies not just by input but by source within that input - try the range for each source, using the relevant Listening Mode button, and stop on the one you like best.
logiciel is offline
Old 08-02-2010, 3:11 PM   #3
Thanks for your response. If I want the original sound format with no post processing do I select pure sound?
Old 08-02-2010, 3:13 PM   #4
Yes, it can be quite effective with some sources.
logiciel is offline
Old 08-02-2010, 3:49 PM   #5
Thanks: Gave 4, Got 4
Can you give an example? I'd be interested to see if there's a difference.
jamescarter1981 is offline
Old 09-02-2010, 10:36 AM   #6
Thanks: Gave 0, Got 7
Pure audio is supposed to be the best listening experience as there is 0 post precessing what so ever so you know you should be hearing it as "god" intended :D. Also when this option is enable all video circuitry is disabled so that any chance of any noise (electrical) is removed (even though it is likely to be low to none). Take note when Pure Audio is enabled even the from led screen is disabled.
If for example you was watching a good quality encodes bluray and wanted the absolute best visual and crisp audio then you would select this option.
The next best to this is Direct Audio it does state there is minimal processing (to what extent not known) but this option can be used for in put sources that don't use HDMI)
Emexrulsier is offline
amp, onkyo, options, processing
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
