Quick OLED Summary
| | Post Reply |
| | #1 |
MrWTF
Guest | Quick OLED Summary Advertisement Want to Advertise?
I've been watching the progression of (Polymer) Organic Light Emitting Diodes (P)OLED (previously called LEP - light emitting polymers) since around 2001. I thought I'd share some of the information I've absorbed over this time as a followup to the FAQ sticky. Please feel free to offer corrections as appropriate. The core of the technology is the concept using polymers which glow red, green or blue when electricity is passed through them. This has the following advantages:
The main leader in the technology appears to have been Cambridge Display Technology (CDT). They have achieved 62,000 hours of blue lifetime at 400cd/m^2. CDT were purchased by Sumitomo corporation in 2007 which seems to imply that their technology was superior to their main competitor Universal Display Corporation. P-OLEDs are already in use in many small devices with short lifetimes such as mobile phones, electric razors and small LED displays. CDT has also discovered that when light shines on P-OLEDs electricity is produced. This means OLEDs in reverse can act as efficient solar cells and will be vastly cheaper to produce than traditional solar cells. What this means is cheap self powered displays on everyday items like food packaging could soon be possible. Working proof of concept prototypes have been produced, including this 40inch OLED TV by Epson in 2004. Last edited by MrWTF; 05-01-2008 at 3:35 PM. |
| Quote |
| | #2 |
| Veteran Member | Re: Quick OLED Summary
You might like to add some details about which companies have promised to deliver what type of OLED device and when....
| Quote |
| | #3 |
Are these displays fixed pixel like LCD or Plasma, or are they capable of doing multiple resolutions without scaling (like CRT)?
| Quote |
| | #7 |
What a shame, we've just taken the biggest leap backwards in 40 years with display technology. Upscaling will ever match native resolutions, we haven't got anywhere near the processing power to do it in real time 60 frames per second. |
| Quote |
| | #8 | |
| Member | Re: Quick OLED Summary Quote:
If the output degradation is know, it could be automatically compensated for but I accept that increasing the current to compensate for the drop off in brightness will only cause the brightness to degrade even faster. If the blue could be sorted out, the potential is tremendous. On the other hand, if the display can be "printed", why not recycle it, because the cost should be very low. It also seems that these displays could be screen printed with precision stainless steel screens (as used for printed circuit board solder paste deposition). Things are certainly getting very interesting on a number of fronts. I personally can see me changing TVs several times in the next 10 years. ![]() | |
| Quote |
| | #9 | |
Can you imagine 720 x 576 pixels on a 52" display. The steps in diagonal lines and lines just off the horizontal would look terrible. A good scaler will smooth these steps out over several pixels, producing a far better picture. As for processing power, I do agree to some extent but processors and dedicated asics are getting faster every day. Things will get better and better for less and less notes. | |
| Quote |
| | #10 |
| Senior Member | Re: Quick OLED Summary
I have to say this OLED picture looks completely stunning on a 27" 1080p display http://www.engadget.com/photos/sonys...hdtv-1/128897/ |
| Quote |
| | #11 | ||
See some of the ones Sega use in Ghost Squad and Outrun2SP The average person though does not have room for a 'large screen' TV, with most buying between 26" and 32". For the home user and especially gamers, a multi res capable display would be best. I've yet to see upscaling match a resolution being displayed natively, and that being on a small 26" screen. The upscaling just made things look blurrier than before, lacking shapness and clarity overall, especially on text, counters and fine details etc. Quote:
In my opinion fixed pixel tech is completely the wrong way to go, and in a few years they could have a CRT that is only 3" deep, and multi-sync. A flat display which doesn't remove features for the sake of style. The current situation is both dipressing and completely avoidable. | ||
| Quote |
| | #12 |
KyoDash, don't forget that CRTs have fixed pixel pitch (in fact on wide screen CRTs they are not even that - if you look at the pixel stripes on a widescreen CRT they get bigger as you move away from the centre of the screen). For computer CRTs the dot pitch is fixed on CRTs. The "analogue" scanning which produces the picture overlays the actual pixel size on top of this fixed pixel pitch, which can mean that 1.5 pixels on the screen are used for 1 pixel of information. Compound this with anamorphic 16:9, where 720 x 576 pixels are stretched horizontally, resulting in rectangular pixels and you begin to see what a compromise CRT is. At least with 1920 x 1080 you are getting exact pixel mapping of the picture data to the display. When a 1080 native display is used to display a 720 x 576 signal, the lower resolution pixel detail is (in crude terms) stretched over several pixels, to fill the screen, as with a CRT. What scalers do, which CRTs do not do, is analyse adjacent pixels to provide smoother transitions between what would be big pixel steps. If you want the same "multi resolution" effect as a CRT, the way to do it would be to have many more pixels on the screen than were needed, so that the same crude scanning technique could be applied. I can't see any display manufacturer doing this because it would cost a fortune and be moving away from 1:1 pixel mapping. |
| Quote |
| | #13 |
how would my 25" 10+ year old sony crt handle hd tv? or is that not possible? for example when analogue gets switched off in 2012 (in london), will it be possible to watch hi def tv as a broadcast through an analogue tv? |
| Quote |
| | #14 | |
| Senior Moderator | Re: Quick OLED Summary Quote:
Short answer: it won't. Longer answer: it won't need to. At least in the medium term, all broadcasts will be available as, or boxes will be able to convert to, standard PAL TV resolutions, for use by people with TVs such as yours. (Please continue THIS subject in, say, the CRT TV forum, thanks). | |
| Quote |
| | #15 | |
| Quote |
| | #16 |
Fascinating concept. Does this mean that in a few years time (ok, maybe 5+) we could see TV's being produced almost like wallpaper? So you flat screen TV really could be flat against a wall (or even on your ceiling as I assume they're a lot lighter), and almost any size? As for advances in technology, as little as 5 years ago you could pay up to £5000 for a portable 7" lcd DVD player, now they give them away! |
| Quote |
| | #17 |
There are several components - the encasing, the OLED and the electronics. At the moment the electronics are still based on traditional rigid silicon, but organic (ie plastic) TFTs are coming (http://www.youtube.com/watch?v=rYc4dnVs4RM) which will permit flexy displays. Then you'd have to hope we've gone to wireless HDMI and wireless power too.
| Quote |
| | #21 |
DLP. I was amazed at how good the image still looked. As you got to about 6' away you began to see the grid lines caused by the pixel boundries but at my viewing distance of 13' it looked brilliant. Your own thread makes it quite clear that it is all dependant on where you sit relative to the screen. Optimum screen size/viewing distance |
| Quote |
| | #22 | |||
Various projection methods can have no pixel patterning and be truly analogue such as the Eidophor, anything similar using the Schlieren effect, anything using separate primary displays (such as three CRTs) and anything using optical scanning (via rotating, oscillating or deforming prisms, mirrors, lenses etc.) with a modulated light source.![]() Quote:
What you say only applies to single tube displays, not optically combined displays from three separate CRTs.
| Quote |
| | #23 | |
| Senior Member | Re: Quick OLED Summary Quote:
CRTs can perform well at a variety of resolutions but don't come anywhere close to fixed-pixel displays running at native resolution. Knobbling the potential for the sake of legacy sources is incredibly short-sighted. | |
| Quote |
| | #24 | |
It is indeed, but for the next 5 to 10 years in the UK at least, most sources being used will be between 480i and 1080p, with 480i/480p/720p and 1080i being the most used. Even HD is divided up into three resolutions, SKY insist on 1080i (best suited to CRT, with gaming being largerly 720p, and BluRay 1080p. Also PC monitors really need to be multi-res native. Case in point, I use 800x600 or 1024x768 for web browsing and most desktop uses, and 1280x1024 for any Imaging or Graphics work I might be doing. I don't need extremely small pin sharp text for Word, Internet and gaming. My biggest issue with fixed-pixel displays other than scaling, is the fact that most are too sharp for current gaming, producing a more artificial look even when correctly calibrated. LCDs more so than CRT PC monitors, which on some resolutions look too sharp around the edges. More a case of much needed enhancements in real time rendering than an issue with the display (Video or film sources don't suffer from this problem). I don't see why we as consumers cannot have the choice of superior technology which can do what CRT has been doing for years. Anyway I'll be waiting for OLED as I find phosphor based displays more pleasing to the eye, Plasma, CRT. Hopefully they will put decent scalers inside these TVs, even if the cost of a 26" will be double the price of an LCD equivilent. So far I've found LCDs with glass screens to produce a better image than those without, but they don't seem to make TVs like this, just monitors. Another annoyance. Currently I'm stuck with a 4:3 240p/480i CRT as the picture on LCDs just doesn't cut it for me, compared with a good 480p CRT, which I'm too late to really get hold of (too much waiting on Samsung for their poor excuse for a HD CRT). I just hope that with OLED they really deliver. Quote:
| Quote |
| | #25 | ||||||
| Quote |
| | #26 | ||
Trouble is nobody really cares about anything these days, and this is the attitude which is currently ruining our society, and limiting consumer choice. And not having a choice is the worse thing of all. | ||
| Quote |
| | #27 | |||
| Quote |
| | #28 | |||
Asking for a TV to be of that standard, and do 31 to 67khz, or even 31 to 45khz may be asking too much. That's much better than those SFP Sony CRTs. With regards to the level of performance a 'consumer CRT TV' could do, then yep, the high end of performance would be noticeably lesser in some areas. Just like a home CRT doing 480p compared to a Nano arcade monitor doing the same, which in turn is worse than my PC monitor for sharpness. That would be my compromise, though. The choice I would like, and many other gamers would also. I think there is a place for both technologies (multi-scan & fixed-pixel, not just CRT) to grow and co-exist. After all, mult-res displays can yield high profit margins than flat panel alternatives. Ultimately it isn't going to happen, and the loss leader method of business is here to stay. Onwards to OLED and FED. Last edited by KyoDash; 09-03-2008 at 11:04 PM. | |||
| Quote |
| | #29 | |
| Prominent Member | Re: Quick OLED Summary Quote:
| Quote |
| | #30 | |
| Veteran Member | Re: Quick OLED Summary Quote:
The biggest problem with CRT is size. You can make a CRT computer monitor that isn't outrageously large because the screen is small. But if you wanted to make a 65" CRT screen capable of accurately displaying 1920x1080 you would need a tube five feet long. The sheer size and weight of a device like that (not to mention the cost of manufacture) makes it a commercial impossibility. CRT projection gets round some of the size problems, and is a technology that I think was abandoned prematurely, but even that has issues above and beyond those of direct-view CRT (poor ANSI contrast, for example). What we need is not CRT, but a fixed-pixel technology which is capable of emulating CRT's black levels and colour accuracy. Now that SED is essentially dead, OLED is the best hope for that. | |
| Quote |
| Post Reply |
E. & O.E.
LinkBack URL
About LinkBacks
