Originally Posted by plague1392 Sorry, I misread your earlier post. What I have against it is if you compare a wobbulated and non-wobbulated 720p DLP set the non-wobbulated version will have a clearer, more focused image. |
Yes, but that's only true of the first-generation 720p devices. They are fairly cr*p in a number of ways: the contrast ratio is pretty dismal too. But 1080p wobulated sets don't suffer from any of those issues. I suspect your objection to wobulated 1080p systems is based more on prejudice than observation - and I bring it up only because you were giving MrWTF such a hard time for doing pretty much exactly the same thing about RP in general.
Originally Posted by plague1392 If, as I assume you believe, there's no degradation of the image from wobbulation then why would TI have bothered to release a non-wobbulated 720p chip? Clearly if there was no disadvantage they would have stuck with wobbulated chips to keep production costs down. |
I think it took them a while to get wobulation working; IIRC the non-wobulated 720p chips came out
before the wobulated ones, not after; wobulation is a way to achieve similar quality at a lower cost.
Probably a better question would be, why do they use non-wobulated 1080p chips in front projection systems? I suspect the answer to that is at least partly "because they can"; 3-chip DLP projectors still sell for 5-figure sums, while 1080p DLP televisions (in the US) sell for less than comparable plasma screens do.
If there is a difference in quality it's something that will only show up when you blow up the picture to the sort of size used in high-end front-projection systems: 1080p DLP RPTVs get very good reviews, and certainly don't exhibit any of the problems associated with wobulated 720p.
Originally Posted by plague1392 Anyway, I think that's going a bit off topic. Has anyone found any news related to the laser TVs yet? |
I'm still too depressed to look because of Sony's announcement that they're abandoning RPTVs entirely. I was
really looking forward to seeing what a laser-driven SXRD rear pro TV would be like, and they had previously said that next year's model was going to be laser-powered. Now there won't even be a next year's model at all.
