Originally Posted by raigraphixs what technology will eliminate for good;
- image burn - dead pixels
- motion-blur |
Any technology not based on phosphors is immune to screen-burn. So CRT, plasma and SED all suffer from it, while LCD, LCOS, DLP and OLED do not.
All pixel-based technologies suffer from dead pixels and always will. CRT is the only thing that doesn't. So all display technologies from now until the end of time will suffer from dead pixels, without exception.
Motion-blur can be the result of a slow response time; this is something which has only ever affected LCD and (to a lesser extent) LCOS. No other technology has the problem. However, all types of display can suffer from motion-blur, because latency (slow response time) is not the only thing that causes blur. A lot of the blur you see on modern displays (even LCD) is the result of poor image processing (such as excessive noise-reduction). This is entirely independent of the display technology.
I suspect that, to get motion-blur down to CRT levels, it may be necessary to go back to a scanning display - that is, a display which is lit up for only a small fraction of each frame and dark for the remainder. It is perfectly possible to do this with LCD, LCOS or DLP if you use an LED or laser-diode light-source. It'll be interesting to see what happens to motion-blur when manufacturers start using scanning backlights.
