Is SED Fixed Resolution?
Old 18-07-2006, 4:27 PM   #1
Sarah Nya
Posts: n/a
See topic.
I'm just interested if this will be the case and if so will we still have the same problems displaying at a non native resolution as with LCDs?
I really would like an HD TV that can handle SD as well
Old 18-07-2006, 5:09 PM   #2
jaguar's Avatar
6,574, Level: 19
Points: 6,574, Level: 19 Points: 6,574, Level: 19 Points: 6,574, Level: 19
As a friend once said to me "We can't solve problems we can only replace them with other problems."
Old 18-07-2006, 9:25 PM   #3
8,966, Level: 22
Points: 8,966, Level: 22 Points: 8,966, Level: 22 Points: 8,966, Level: 22
Thanks: Gave 38, Got 33
It is fixed resolution, it has loads of tiny CRTs (basically) that make a pixel each, nothing is scanned like a CRT.
Old 19-07-2006, 7:37 AM   #4
Sarah Nya
Posts: n/a
So does that mean we will have the same problems ?
Anything better in the pipeline?
Old 19-07-2006, 9:07 AM   #5
GasDad's Avatar
4,993, Level: 16
Points: 4,993, Level: 16 Points: 4,993, Level: 16 Points: 4,993, Level: 16
Thanks: Gave 1,509, Got 722
There doesn't need to be anything better - if and when SED's come to market they will almost certainly all be at a 1900x1080 resolution. That is more than high enough to display a SD picture without problems. (In fact the vertical resolution is exactly twice that of SD, which makes scaling easy)
James
Old 19-07-2006, 9:38 AM   #6
Sarah Nya
Posts: n/a
I hope so, it would be lovely to have a screen that does it all.
Just have to be patient now...
Old 19-07-2006, 10:24 AM   #7
8,966, Level: 22
James
SD is 576 so not exactly twice. All the screen needs is a good scaler but this will make the prices even higher
Old 19-07-2006, 10:41 AM   #8
6,620, Level: 19
Points: 6,620, Level: 19 Points: 6,620, Level: 19 Points: 6,620, Level: 19
PAL SD is 576 lines but doesn't that include the overscan area which can be cropped to 540 lines without loss of important picture info?
Old 19-07-2006, 11:17 AM   #9
GasDad's Avatar
4,993, Level: 16
That is my understanding as well.
James
Old 19-07-2006, 11:40 AM   #10
8,966, Level: 22
PAL is 625 lines (including the bits that are already cropped to make 576), overscanning is hardly state of the art, fixed pixel displays shouldn't overscan at all really. If you want your very expensive state of the art TV to cut off some picture then thats fine!
Old 20-07-2006, 8:33 AM   #11
6,620, Level: 19
I think I'd happily sacrifice some redundant scanlines in exchange for better picture quality. Scaling is every flat panel's Achillies heal, IMO.
Old 20-07-2006, 10:16 AM   #12
JagoPlasma's Avatar
12,664, Level: 27
Points: 12,664, Level: 27 Points: 12,664, Level: 27 Points: 12,664, Level: 27
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 847, Got 387
correct, listen to what he said
and 1080 is 1125 lines
Old 20-07-2006, 11:13 AM   #13
Senior Moderator
LV426's Avatar
42,418, Level: 50
Points: 42,418, Level: 50 Points: 42,418, Level: 50 Points: 42,418, Level: 50
Activity: 32.4%
Activity: 32.4% Activity: 32.4% Activity: 32.4%
Thanks: Gave 1,530, Got 1,592
PAL is 625 lines. 49 of those lines contain no picture information whatsoever. They contain switching information and other stuff which instructs the display on how to make the picture.
The remaining 576 lines contain picture.
Overscanning is not done so as to reduce the 625 to 576 i.e. to hide the 49 lines that contain no picture.
Overscanning is done ON the 576 lines that remain. It is an intentional and correct part of any SD TV system that 5% of the height and width of the picture (that's the 576 lines) are not displayed. A correctly adjusted display will therefore overscan by 5% in both directions and hence display something like 550 lines.
Even a "digital" display should do this. It's often the case that an SD TV picture contains junk in the extemities of the image - for example, anything sourced from or played back on tape will have headswitching distorion at the bottom. It is quite right and proper that this is hidden, even in a digital display.
I suspect, though, that the "correct" percentage of overscan will be less than 5% for High Definition, but I haven't yet seen this specified anywhere. I'm sure it is, but I haven't seen it. I doubt, though, that it will ever be zero.
Old 27-07-2006, 1:13 AM   #14
7,944, Level: 21
Points: 7,944, Level: 21 Points: 7,944, Level: 21 Points: 7,944, Level: 21
Thanks: Gave 1, Got 0
Does this mean that dead pixels will still be a poissibility? If so i am disappointed.
Old 27-07-2006, 8:23 AM   #15
6,198, Level: 18
Points: 6,198, Level: 18 Points: 6,198, Level: 18 Points: 6,198, Level: 18
Thanks: Gave 4, Got 27
Of course it's "possible". But i don't know why you should be disappointed, unless it happens to you. In which case you can always return the bloody thing.
Old 27-07-2006, 11:42 AM   #16
14,653, Level: 29
Points: 14,653, Level: 29 Points: 14,653, Level: 29 Points: 14,653, Level: 29
Thanks: Gave 17, Got 62
Problem is the manufacturers will fudge the warranty and cover for dead pixels like most do now.
Nice sig by the way, gotta love bash
Old 27-07-2006, 12:02 PM   #17
8,966, Level: 22
I would think they would be more likely, but the pixels will be so small you wouldn't notice one (remember they will be 1920x1080 not 1024x768 or 1366x768)
