New article on Field Emission tv developments
Old 09-07-2006, 4:23 PM   #1
Pondle
Posts: n/a
Have a look at:
http://technology.guardian.co.uk/wee...813113,00.html
"A 20-inch prototype display is expected by the end of next year and, beyond that, 32-inch or even 42-inch sizes beckon, with production pencilled in for 2009 or 2010".
It's a long time to wait... personally, I can just about hold out for the Toshiba/Canon SED (but if they delay it again, there's gonna be a 50in 1080p Pioneer plasma with my name on it).
Old 10-07-2006, 9:39 AM   #2
Eminent Member
Tejstar's Avatar
126,891, Level: 86
Points: 126,891, Level: 86 Points: 126,891, Level: 86 Points: 126,891, Level: 86
Thanks: Gave 408, Got 993
Goodness me, now we have polymer light-emitting diode (PLED) tv technology to deal with as well. And I thought the current tv market was confusing enough!
Old 17-07-2006, 2:13 PM   #3
Sarah Nya
Posts: n/a
I'm just hoping for something thats as good with HD as an LCD and handles SD as well as an old CRT.
I can hope can't I!
Old 17-07-2006, 4:05 PM   #4
Pondle
Posts: n/a
I can hope can't I!
I think SED will fit the bill...
http://www.canon.com/technology/cano...ation/sed.html
http://www3.toshiba.co.jp/sed/eng/
Old 20-07-2006, 10:30 AM   #5
JagoPlasma's Avatar
12,664, Level: 27
Points: 12,664, Level: 27 Points: 12,664, Level: 27 Points: 12,664, Level: 27
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 847, Got 387
cant they just make an LED tv? as in every pixel is made out of 3 leds RG&B? imagine the black levels lol cant get blacker than off!
colour reproduction might be a bit pants tho
Old 20-07-2006, 12:38 PM   #6
5,339, Level: 17
Points: 5,339, Level: 17 Points: 5,339, Level: 17 Points: 5,339, Level: 17
Thanks: Gave 15, Got 36
Yes, it's OLED. All the LCD guys are working on it. The early ones look really good, BUT (and it's a big but) the lifetime especially of blue is very poor (1500 hrs or so). In addition there is a problem in that the materials are degraded by moisture. Solving the encapsulation so that humidity in the air doesn't eat the display is a huge hurdle.
Dream on until after 2010. But the potential for the technology is fantastic. Remember that LCDs will have had another 5 years of development too however, and much of what we discuss at present about motion etc will have been solved.
Old 20-07-2006, 1:36 PM   #7
JagoPlasma's Avatar
12,664, Level: 27
Activity: 2.4%
oled isnt the same as led, im talking about the leds that you solder onto a circuit board lol, imagine the head generated from the thing!
Old 21-07-2006, 9:00 AM   #8
5,339, Level: 17
Bearing in mind the pixel size you'd need a 400" display - but they already exist for public displays. There's a big one outside Amsterdam Airport.
As LED uses silicon, the only solution would be to tile wafers..and at $50k for a 12" wafer not exactly a consumer product...
Old 22-07-2006, 11:14 PM   #9
4,878, Level: 16
Points: 4,878, Level: 16 Points: 4,878, Level: 16 Points: 4,878, Level: 16
Thanks: Gave 2, Got 10
As SED is still fixed resolution it's more than likely it won't be much better at all for SD material. The TV would have to have a good scaler and de-interlacer to do that, and that certainly won't be as good as 480i or 480p done natively on a CRT. Considering you need a scaller costing around £800 to achieve excellent results.
It would be better for them just to produce a multi-sync CRT without any slim designs. At around 26" 28" although expensive is easily possible to produce good geometry, colour, brightness and contrast levels.
SED cannot scan like a CRT so it cannot adjust it's resolution, meaning panels although going to be CRT quality for naitve res stuff, anything else won't look all that great.
