With the European PS3 being lower spec'd than the US model, will you be buying one?
| View Poll Results: With the European PS3 being lower spec'd than the US model, will you be buying one? | |||
| Yes I'm having my PS3 anyway | | 118 | 30.03% |
| No, I'm going to buy a US or Japanese model | | 51 | 12.98% |
| I was going to get a PS3, but I'm not going to bother now | | 190 | 48.35% |
| I already got a US or Japanese PS3 | | 34 | 8.65% |
| Voters: 393. You may not vote on this poll | |||
| | Post Reply |
| | #1 |
| Founder | With the European PS3 being lower spec'd than the US model, will you be buying one? |
| Quote |
| | #2 |
| Distinguished Member | Re: With the European PS3 being lower spec'd than the US model, will you be buying on |
| Quote |
| | #3 |
| Eminent Member | Re: With the European PS3 being lower spec'd than the US model, will you be buying on |
| Quote |
| | #4 |
| Quote |
| | #5 |
| Prominent Member | Re: With the European PS3 being lower spec'd than the US model, will you be buying on |
| Quote |
| | #6 |
| Quote |
| | #7 |
| Guest | Re: With the European PS3 being lower spec'd than the US model, will you be buying on |
| Quote |
| | #8 |
| Senior Member | Re: With the European PS3 being lower spec'd than the US model, will you be buying on |
| Quote |
| | #9 |
| Member | |
| Quote |
| | #10 |
| Quote |
| | #11 |
| Quote |
| Thanks from: | Matty6776 (05-03-2007) |
| | #12 |
| Quote |
| | #13 |
| Quote |
| | #14 |
| retired member | Re: With the European PS3 being lower spec'd than the US model, will you be buying on Last edited by Seth Gecko; 06-03-2007 at 1:11 PM. |
| Quote |
| | #15 |
| Member | Re: With the European PS3 being lower spec'd than the US model, will you be buying on Last edited by Gaz B - 123; 07-03-2007 at 12:45 PM. |
| Quote |
| | #16 |
| Quote |
| | #17 |
| Quote |
| | #18 |
| Founder | Re: With the European PS3 being lower spec'd than the US model, will you be buying on |
| Quote |
| | #19 |
| Quote |
| | #20 |
| Quote |
| | #21 |
| Quote |
| | #22 |
| New Member | Re: With the European PS3 being lower spec'd than the US model, will you be buying on |
| Quote |
| | #23 |
| Quote |
| | #24 |
| Quote |
| | #25 |
| Quote |
| | #26 |
| Quote |
| | #27 |
| Quote |
| | #28 |
| Ex Member | Re: With the European PS3 being lower spec'd than the US model, will you be buying on |
| Quote |
| Post Reply |
The truth is that sony is removing the chip for ps2 bc from all region machines. Fair enough there is machines out there with the chip inside but does it really matter. For me no because i know I am getting a quality machine and those who cancelled are missing out.
E. & O.E.
LinkBack URL
About LinkBacks
