Poll. TV settings and features
View Poll Results: TV Settings, menu options and features important to you. Multi choice..
I am happy just to plug the TV in and select a Picture mode. 14 4.71%
I would like a TV that walks me through correct set up of the main controls for picture. 88 29.63%
I want my TV to show me the best image possible for how material should be seen. 178 59.93%
I want modes like THX and Pure that get the TV close to the standards out of the box 148 49.83%
I want menu options such as Gamma control, Greyscale (white balance) control and a CMS 141 47.47%
I want a TV with memories for all the inputs 196 65.99%
I want a TV with a preset for watching HD TV as it should be displayed 139 46.80%
I want a TV that has a preset for watching SD TV as it should be displayed 120 40.40%
I base my buying decisions on the picture settings and menus available in a TV 61 20.54%
I base my buying decisions on a TV that has a nice design not accurate pictures 6 2.02%
I base my buying decisions on design BUT it also has to have accurate image 97 32.66%
I will set up the TV using a set up DVD/BD 130 43.77%
I will Calibrate the TV by learning how to use a meter/software 49 16.50%
I will pay an ISF calibrator to Calibrate my TV 48 16.16%
I have no intention of setting up or calibrating my TV 11 3.70%
I have no intention of paying for ISF 75 25.25%
Accurate image quality for colour and greyscale is important 162 54.55%
I base my buying decisions on price alone 1 0.34%
I do not need extra menus with gamma, CMS etc 14 4.71%
I want a TV that needs no calibration at all, its perfect out of the box to the standards 85 28.62%
I will pay extra for a TV with ISF, THX and Accurate picture modes 98 33.00%
I expect ISF, THX and Accurate picture modes at any price level 41 13.80%
I will not pay extra for ISF, THX or accurate modes 33 11.11%
I have no interest in any of the options in this poll, my TV is fine to me. 7 2.36%
Brand loyalty is important to me 35 11.78%
Price is key to me over quality 5 1.68%
Multiple Choice Poll. Voters: 297. You may not vote on this poll
Old 18-05-2009, 5:25 PM   #1
AVF Editorial Manager
Phil Hinton's Avatar
106,654, Level: 79
Points: 106,654, Level: 79 Points: 106,654, Level: 79 Points: 106,654, Level: 79
Activity: 14.4%
Activity: 14.4% Activity: 14.4% Activity: 14.4%
Thanks: Gave 1,069, Got 4,185
Just a quick poll to see how forum attitudes are to TV controls or the lack of them. Things like gamma selection, Colour management systems, greyscale (white balance) and interactivity with set up.
Does the TV you are thinking about buying have to offer you the controls to properly set up your TV. Do expert modes, ISFccc and THX make you look at that TV in a better light than one which doesn't? Or are you not that bothered about the level of settings available?
Do you want the best from your TV? Are you prepared to calibrate it yourself or consider hiring someone to do it. Would you like a system that walks you through correct set up of the main controls for your room and sources? Are test patterns built in to a TV an added feature for you. Is your goal to achieve an image which is accurate to what the broadcast and film material is supposed to be shown at?
This is a multi choice poll and you can vote for all the options that are important to you.
Old 18-05-2009, 5:29 PM   #2
Conspicuous Member
chelsea.tone's Avatar
18,837, Level: 33
Points: 18,837, Level: 33 Points: 18,837, Level: 33 Points: 18,837, Level: 33
Thanks: Gave 792, Got 982
Re: Poll. TV settings and features
No poll showing Phil
Tony
Old 18-05-2009, 5:44 PM   #3
106,654, Level: 79
Activity: 14.4%
Should be there
Old 18-05-2009, 5:57 PM   #4
Conspicuous Member
Monarch's Avatar
21,415, Level: 35
Points: 21,415, Level: 35 Points: 21,415, Level: 35 Points: 21,415, Level: 35
Thanks: Gave 394, Got 1,174
It's there now, I agree with most of the points, apart from a decent few near the bottom, there are a few things which I'm kind of in the middle of though (personally). I ticked the box for buying a TV based on picture settings etc...it's more of a considerable consideration but ultimately price and other factors will override that.
Also I haven't calibrated either of my TVs, and I don't necessarily intend to (I'm deliberating in the back of my mind) but I have spent several hours settings it up, trying combinations of calibrated and uncalibrated settings posted on the net and tweaking them myself etc...I know I can get a little more out of them but I personally don't have a need to get the absolute best like some people do.
I also ticked the box for having a perfect TV out of the box, I do want that, but I don't want the isf people without a job...ideally it would just be perfect for me as I don't have the money to pay for a pro to do it
Anyway, enough of my running commentary, it'll be interesting to see peoples thoughts on these things
Old 18-05-2009, 6:06 PM   #5
Conspicuous Member
18,837, Level: 33
Originally Posted by Phil Hinton View Post
Should be there
Sorted
Old 18-05-2009, 6:44 PM   #6
16,600, Level: 31
Points: 16,600, Level: 31 Points: 16,600, Level: 31 Points: 16,600, Level: 31
Activity: 4.5%
Activity: 4.5% Activity: 4.5% Activity: 4.5%
Thanks: Gave 88, Got 480
I definitely agree that user adjustability really helps to sell a set for me.
For example, compare the Panasonic G10 to the Sony W5500. On the Sony, not only do you get white balance controls, you get to set them, and all other picture settings independently per input. You can also set the custom and standard modes differently within the same input. Regardless of the technological differences of the televisions, this is an undoubtedly major advantage of the Sony.
Old 19-05-2009, 12:06 AM   #7
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Points: 20,236, Level: 34 Points: 20,236, Level: 34 Points: 20,236, Level: 34
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 369, Got 613
Only reason I didn't select "I want a TV that needs no calibration at all, its perfect out of the box to the standards " which would have been the only option worth picking, is because it will never exist.
Phil Hinton (19-05-2009)
Old 22-05-2009, 10:38 AM   #8
KhalJimbo's Avatar
20,444, Level: 34
Points: 20,444, Level: 34 Points: 20,444, Level: 34 Points: 20,444, Level: 34
Activity: 16.2%
Activity: 16.2% Activity: 16.2% Activity: 16.2%
Thanks: Gave 1,009, Got 603
I chose according to what I beilieve a good TV should be, personally I dont the whole ISF settings out of the box are good because, it cant be ISF callibrated out of the box because ISF doesnt know what room the TV is going in (unless I have completely misunderstood it).
Also the whole picture setting dont mean much to me since I only use standard then use a DVE BR to set it up, however I would like more control over gamma and greyscale without having to go into the systems menu and reverting all my settings at the same time.
Old 29-05-2009, 10:00 PM   #9
2,382, Level: 11
Points: 2,382, Level: 11 Points: 2,382, Level: 11 Points: 2,382, Level: 11
Thanks: Gave 39, Got 18
Does it mean you don't want one though, cos I still think it would be nice
I like something that has a much user customisation as possible, and I'll pay
more for a better picture / features but at the end of the day, I'll only pay
so much for a TV, thus I'm one of the (surprising to me) few who've
ticked price as being the overall decider. If it wasn't, wouldn't we all have
Kuros/ 10K+ Projectors [Or is that another debate ;]
Old 20-07-2009, 12:10 AM   #10
Illustrious Member
namuk's Avatar
40,916, Level: 49
Points: 40,916, Level: 49 Points: 40,916, Level: 49 Points: 40,916, Level: 49
Activity: 58.8%
Activity: 58.8% Activity: 58.8% Activity: 58.8%
Thanks: Gave 1,068, Got 2,470
That is the biggest poll i have seen, but i voted , i just hope Phil does not bring out a TV.. it will take an hour to switch on ..
Old 14-08-2009, 8:15 PM   #11
tvbox's Avatar
7,837, Level: 21
Points: 7,837, Level: 21 Points: 7,837, Level: 21 Points: 7,837, Level: 21
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 1,470, Got 241
All i want is for the tv to display SD pictures better than a CRT. No need to go into all the details or 'THX', but need a bit of adjusting of course
HTML code is On
