Sorting Data
Old 30-06-2010, 6:43 PM   #1
2,110, Level: 10
Points: 2,110, Level: 10 Points: 2,110, Level: 10 Points: 2,110, Level: 10
Sorting Data
Is it possible to sort data and put the lowest number to the top of the list. For example i have in column A, lots of numbers. Some of these numbers are the same, what i am trying to do is to sort column A and sort the column so the lowest unique number is at the top. Just to explain a bit more, for arguments sake say i have in cell A1 23-A2 23-A3 32, is it possible to disreguard the 23 and put 32 to the top of the sort. I am Using excel 2003. Hope this makes sense. Cheers in advance.
Old 30-06-2010, 7:18 PM   #2
hyperfish's Avatar
2,862, Level: 12
Points: 2,862, Level: 12 Points: 2,862, Level: 12 Points: 2,862, Level: 12
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 210, Got 286
This related to you other post?
You want to sort all the bids in descending order?
Old 30-06-2010, 7:48 PM   #3
2,110, Level: 10
sorting
In a way yes. But i would like to know the lowest bid all the way through the bidding. So if say 23 was bid twice i could have the screen say sorry your bid is not unique. Thanks again for trying to help.
Old 30-06-2010, 9:46 PM   #4
hyperfish's Avatar
2,862, Level: 12
Activity: 2.4%
I see.
For the duplicate part use conditional formatting. Select the column where the bids will be input. Go format/conditional format/highlight cell rules/duplicates. Set the cell to a contrasting colour. This will activate if a duplicate non unique entry occurs.
To keep a check on the lowest bid. Enter each bid within the same column. Click on that column and hit the sort button (Z-A). Look here.
Or, you could use conditional formatting again. Select the column where the bids will be input. Go format/conditional format/top,bottom rules/bottom 10 items/adjust to one. Set the cell to a contrasting colour.
Sorry, it's difficult to get this over clearly. If I loose you, feel free to ask and I will knock you up a sheet.
Old 30-06-2010, 10:36 PM   #5
Assured Advertiser
graham.myers's Avatar
15,590, Level: 30
Points: 15,590, Level: 30 Points: 15,590, Level: 30 Points: 15,590, Level: 30
Activity: 25.0%
Activity: 25.0% Activity: 25.0% Activity: 25.0%
Thanks: Gave 162, Got 559
to actualy remove the rows and leave just the unique rows - I assume you are doing some kind of reverse auction where the lowest unique bidder wins - then you're probably better using a subroutine
Code:
Sub DelDups()
    Dim Rng As Range
    Columns("A:A").Insert Shift:=xlToRight
    Set Rng = Range("A1:A" & Range("B65536").End(xlUp).Row)
    With Rng
        .FormulaR1C1 = "=COUNTIF(R1C2:R100C2,RC[1])"
        .Resize(, 2).AutoFilter Field:=1, Criteria1:=">1", Operator:=xlAnd
        .SpecialCells(xlCellTypeVisible).EntireRow.Delete
    End With
    Columns("A:A").Delete Shift:=xlToLeft
End Sub
I'd work on a copy of the original data though! so you have a compete list of bids
Old 31-07-2010, 10:51 AM   #6
Tembo11's Avatar
534, Level: 4
Points: 534, Level: 4 Points: 534, Level: 4 Points: 534, Level: 4
Thanks: Gave 1, Got 1
why not use conditional formatting and set the formula to use the MIN value of the range. You could use OFFSET to give you a range that allows for extra lines being added
Powered by
 Latest popular product prices
Sun Microsystems StarOffice 5.2
1 price
 £3.30 Click to show/hide the offers
Dell Microsoft Access 2002 XP Be...
1 price
 £10.12 Click to show/hide the offers
Dell Microsoft Access 2003 Begin...
1 price
Dell Microsoft Windows XP Beginn...
1 price
Dell Home Networking (90-day lic...
1 price
Dell Microsoft Word 2002 XP Begi...
1 price
Dell Microsoft Word 2000 Beginne...
1 price
Dell Time Management (60-day lic...
1 price
 Updated February 12th at 2:30pm. Prices include delivery.
