Help! How do i transfer contacts from my Sony to my Nokia???
Old 08-11-2009, 9:44 PM   #1
3,572, Level: 14
Points: 3,572, Level: 14 Points: 3,572, Level: 14 Points: 3,572, Level: 14
Thanks: Gave 61, Got 20
Hi, and thanks for looking.
I've just bought a brand new Nokia 5530 today. Unfortunately 7 hours later i still can't use it as I've spent all afternoon trying to export / back-up my Sony Ericsson, and import the contacts over to the Nokia 5530.
All i've managed to do so far is sync my Sony with Windows Vista Contacts. The Nokia Ovi Suite software is terrible, and i can't find a way of syncronising the phone with Windows Contacts.
I've therefore tried to get my contact details into MS Outlook 2007. The Sony Suite doesn't appear to support exporting contacts into that, so i've tried getting my Windows Contacts into MS Outlook, but i can't find a way to do that either.
Is there any way i can get my contacts over. I'm getting pretty desperate now, and don't want to have to enter them all manually.
Also, is the Nokia Ovi Suite the only application i can use with my 5530, as so far it seems to be an awful piece of software.
Thanks!
Old 09-11-2009, 3:23 AM   #2
SteveAWOL's Avatar
4,180, Level: 15
Points: 4,180, Level: 15 Points: 4,180, Level: 15 Points: 4,180, Level: 15
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 260, Got 156
Re: Help! How do i transfer contacts from my Sony to my Nokia???
Sorry to hear about your problems monkey butler. I recently changed phones from a Sony Ericsson K800 to a Nokia N82 and iirc I synchronized my Sony with Outlook (2002 in my case) using SE Suite then used the Nokia Suite to do the same with the N82.
Though maybe those Suites haven't yet been made fully Vista compatible yet, in which case you could always try the old fashioned method of copying the contacts from old phone onto SIM card then inserting SIM into new phone and copying them into the new phone' Contacts.
Old 09-11-2009, 4:07 PM   #3
2,050, Level: 10
Points: 2,050, Level: 10 Points: 2,050, Level: 10 Points: 2,050, Level: 10
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 0, Got 3
Just stick your sim in your new phone...
Old 09-11-2009, 4:40 PM   #4
6,434, Level: 19
Points: 6,434, Level: 19 Points: 6,434, Level: 19 Points: 6,434, Level: 19
Thanks: Gave 19, Got 41
If your on o2 you can use bluebook to transfer your numbers as long as both phones are supported.
Old 10-11-2009, 4:14 PM   #5
Uridium's Avatar
33,239, Level: 44
Points: 33,239, Level: 44 Points: 33,239, Level: 44 Points: 33,239, Level: 44
Activity: 20.6%
Activity: 20.6% Activity: 20.6% Activity: 20.6%
Thanks: Gave 527, Got 1,810
Can't you just send them over by Bluetooth?
Old 11-11-2009, 6:16 PM   #6
3,572, Level: 14
Sorted!
I exported all of my Sony contacts to Windows Vista Contacts (no option to export to Outlook on the Sony PC Suite).
I then ran the Nokia Ovi software (which is awful!). Ran a sync which said it synced 1 item, a test contact on my phone. There were no actual options in the application to sync contacts (weird).
Anyway, although it told me that it had only synced 1 item, the test contact, when i checked the phone later it had brought all of the contacts over, just not told me in the Ovi suite.
Powered by
 Latest popular product prices
Nokia 100
2 prices from
 £23.21 Click to show/hide the offers
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia C2-02
2 prices from
 £78.49 Click to show/hide the offers
Nokia C3-00
2 prices from
 £80.56 Click to show/hide the offers
Nokia 6303i classic
1 price
 £100.99 Click to show/hide the offers
Nokia C3-01
2 prices from
 £124.14 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Nokia C5-00
2 prices from
 £122.99 Click to show/hide the offers
 Updated February 13th at 7:30pm. Prices include delivery.
