Originally Posted by alchemistkevin I've had an E71 - probably the best phone ever made by Nokia - reliable and stanble - E63 should be similar I'd say...
You wouldn't regret it at £167 me thinks.... |
Will be going into town tomorrow to have a look at one on the Virgin network. if I like the use of it, then I will consider buying on Virgin, if not, then I will buy sim free and use it with my ASDA mobile sim.
Can you tell me, after using your E71, what is your typical data consumption like? Would it be worthwhile getting myself onto a network that offers a data package or would I get away with paying per MB (20p per MB)?
