Buffalo Wi-Fi Adapter and Nintendo Wi-Fi Adapter
Old 21-03-2007, 11:18 PM   #1
11,431, Level: 25
Points: 11,431, Level: 25 Points: 11,431, Level: 25 Points: 11,431, Level: 25
Activity: 8.0%
Activity: 8.0% Activity: 8.0% Activity: 8.0%
Thanks: Gave 9, Got 50
Just wondering if the drivers from the buffalo wifi adpater would work with nintendo wifi adapter as it is made by them...
EDIT: Just realised I posted this in the wron forum please move to where you think its should be....
I think it would be better in the PC bit or maybe Nintendo
Old 20-04-2007, 5:07 PM   #2
INSOMANiAC's Avatar
5,298, Level: 17
Points: 5,298, Level: 17 Points: 5,298, Level: 17 Points: 5,298, Level: 17
Thanks: Gave 66, Got 76
Re: Buffalo Wi-Fi Adapter and Nintendo Wi-Fi Adapter
You can use the asus drivers to make it work with PSP AND DS.
Ive done it myself although I cant seem to get the DS to connect in wep mode so I have to play with no security at the moment.
Tutorial here http://www.dcemu.co.uk/vbulletin/showthread.php?t=36057
Theres a simple video to follow and all the files you need.
Old 22-07-2007, 3:05 PM   #3
5,190, Level: 17
Points: 5,190, Level: 17 Points: 5,190, Level: 17 Points: 5,190, Level: 17
Thanks: Gave 36, Got 4
i followed the instructions with no hitches. But i cannot connection with my psp and PS3 (DS and wii is fine). i think its having trouble find the ip and the settings (it doesnt even get to the encryption bit)
any idea where i went wrong?
