Why can't my TV display my N64?
Old 03-02-2007, 12:34 PM   #1
4,547, Level: 15
Points: 4,547, Level: 15 Points: 4,547, Level: 15 Points: 4,547, Level: 15
Hi guys, please help me. I am trying to play my N64 through an s-video cable connection which I had bought off ebay.
This is on my Samsung HDTV.
I have tried just the s-video cable, just the three coloured cables, and all cables connected together and I still have no luck. What am I doing wrong?
Cheers,
Stew
Old 04-02-2007, 12:47 PM   #2
4,453, Level: 15
Points: 4,453, Level: 15 Points: 4,453, Level: 15 Points: 4,453, Level: 15
Thanks: Gave 73, Got 59
Re: Why can't my TV display my N64?
Have you tried the lead and console on another TV, just to check that it isn't the lead playing up?
Old 04-02-2007, 10:19 PM   #3
4,547, Level: 15
Ive tried that mate and yeah it didn't work. Turns out I had to really clean the cartridge connector and also the game.
It has been sitting in the spare room for a few years so thats maybe why.
Thanks for your help though matey.
readingfanman (20-03-2007)
Old 22-03-2007, 5:39 PM   #4
3,435, Level: 13
Points: 3,435, Level: 13 Points: 3,435, Level: 13 Points: 3,435, Level: 13
Thanks: Gave 4, Got 0
If it's a PAL N64 then it will only output composite. If it's NTSC then it should ouput S-video as well.
It is also possible to mod a NTSC N64 to ouput RGB SCART but I don't think it's possible with PAL N64.
Old 13-05-2007, 2:54 PM   #5
INSOMANiAC's Avatar
5,298, Level: 17
Points: 5,298, Level: 17 Points: 5,298, Level: 17 Points: 5,298, Level: 17
Thanks: Gave 66, Got 76
If you ever find your games arent working , try just putting them half way in, works everytime. Same for all cartridge based systems
Old 24-08-2007, 6:35 PM   #6
6,836, Level: 19
Points: 6,836, Level: 19 Points: 6,836, Level: 19 Points: 6,836, Level: 19
Thanks: Gave 44, Got 52
No, PAL N64's also output S-Video.
