x box and vga connection
Old 01-05-2002, 9:23 PM   #1
7,157, Level: 20
Points: 7,157, Level: 20 Points: 7,157, Level: 20 Points: 7,157, Level: 20
Thanks: Gave 1, Got 0
Hi.
can anybody help.
I have a grundig tv with 3 scarts which are all in use , but this tv also he a vga socket.
is it possible to connect my x box this way, and if i do will i get a better result than if i get a box that puts two scarts into one socket?
if it is good to use the vga socket does anybody know where i can get the connections?. at the moment i have one of these multiple connectors which gives me fibre optic sound to my amp and scart/svhs picture connections.
thanks.
Old 02-05-2002, 9:41 AM   #2
titan
Posts: n/a
yes........and yes
look at lik-sang for the appropriate device.
