Dell 2405FPW and Dreamcast display problem
Old 26-03-2006, 2:37 PM   #1
4,172, Level: 15
Points: 4,172, Level: 15 Points: 4,172, Level: 15 Points: 4,172, Level: 15
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 0, Got 4
Have just hooked my Dreamcast up to my Dell 2405FPW, have placed the screen in the vertical position, but the display is upside down. It seems that you can only rotate the Dell one way, clockwise. Is there an option in the monitors menu where you can flip the screen so it will be the right way up???
Old 27-03-2006, 10:45 AM   #2
Big Jim
Posts: n/a
is this for Ikaruga? The only solution I have hear of is to get an alternative mount which will pivot the other direction.
Have a look at the threads on NTSC-uk (http://ntsc-uk.domino.org/search.php?searchid=578831)
