Svideo connections for consoles
Old 18-02-2002, 12:06 AM   #1
monkeyleader's Avatar
21,980, Level: 36
Points: 21,980, Level: 36 Points: 21,980, Level: 36 Points: 21,980, Level: 36
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 202, Got 91
Hey all,
Im about to get my gamecube (usa import) and was just wondering about the best conneciotns. I have a Tosh 40"RP TV which has 3 scart, 1 compoint and svideo. I have the Yamaha 620 amp.
I would really like to be able to plug the cube into the amp - can i do this by svideo ?
I tied with the ps2 but wasnt able to, even tho sony do an ps2-svideo cable ?
ta in advance,
Nige
Old 18-02-2002, 12:18 AM   #2
4,532, Level: 15
Points: 4,532, Level: 15 Points: 4,532, Level: 15 Points: 4,532, Level: 15
Thanks: Gave 15, Got 11
I'm not sure about the GC but I have my PS2 connected to my amp via S-Video and then out from my amp to tv via S-Video to S-Video(or sometimes I use an S-Video to scart lead as I don't have to use the front panel on the tv then). The connector on my PS2 is a PS2 connector with a black box that has 3 composite connections and an S-Video output connection. So if the GC has the ability to output S-Video you should be able to do something similar. BTW I connect my PS2 to my amp via digital cable for sound.
Old 19-02-2002, 12:08 AM   #3
Ten Ten is offline
3,964, Level: 14
Points: 3,964, Level: 14 Points: 3,964, Level: 14 Points: 3,964, Level: 14
yes
the s video cable for the gcube is the same as the one for the n64 and this is how i currently have my gcube connected via my processor. i also have my ps2 connected via s video via my processor too. don't understand why yours didn't work.
