Which connection for UK X-BOX ?
Old 07-02-2002, 1:59 PM   #1
Conspicuous Member
dUnKle's Avatar
42,579, Level: 50
Points: 42,579, Level: 50 Points: 42,579, Level: 50 Points: 42,579, Level: 50
Activity: 4.7%
Activity: 4.7% Activity: 4.7% Activity: 4.7%
Thanks: Gave 352, Got 205
Just about to order my X-BOX but need to know about the connection options.
I would like to be able to connect the console to my amp using and s-video cable and also have 5.1 sound, what do I need to do this ?
Do I need to order anything else besides console and games or will I get what I need in the box ?
Old 07-02-2002, 5:44 PM   #2
annefromuk
Posts: n/a
Good choice of console
For DD5.1 sound you will need to buy a seperate AV Pack for the Xbox.
Microsoft make an Avanced Scart Pack that has optical outputs for 5.1 sound, but as you want to use S-Video the only lead that might fit the bill is the Saitek S-Video Cable but I am not sure it this has DD5.1 output.
Anne
Old 07-02-2002, 6:08 PM   #3
Conspicuous Member
dUnKle's Avatar
42,579, Level: 50
Activity: 4.7%
In one of this months XBOX mags ( the one with free video ) is a small thing on these AV Packs.
Theres not much info on them but the one looks like a small black box which plugs into back of the XBOX.
On the box are some connectors, one looks like it fits and S_video cable and there also seems to be one for an optical cable as well as normal audio cables.
Do you think this is what I need ? Any ideas were I could find out ? Also if it is what I need do you think I then use standard S-Video and optical cables ?
Old 07-02-2002, 7:44 PM   #4
16,050, Level: 30
Points: 16,050, Level: 30 Points: 16,050, Level: 30 Points: 16,050, Level: 30
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 214, Got 235
The official UK site only shows
Advanced Scart - which is RGB scart and has optical output
Standard AV scart - composite to scart with no optcial output
US have
Standard composite - comes with machine no optcial..
Advanced AV - SVHS and stereo audio and optical
Hi Def - Component and stereo audio and optical..
All will work with all systems..so just get a US kit if the UK ones don't suffice..
Old 07-02-2002, 9:20 PM   #5
6,875, Level: 19
Points: 6,875, Level: 19 Points: 6,875, Level: 19 Points: 6,875, Level: 19
Activity: 10.2%
Activity: 10.2% Activity: 10.2% Activity: 10.2%
Thanks: Gave 77, Got 106
Hi Duncan
I`ve seen the box (called Advance AV Pack) in the mag aswell, It would be the one you need if it gets released.
I`m waiting to hear from my local EB store if its going to become available, I`ll let you know if i hear anything.
Carlos
Old 08-02-2002, 12:08 AM   #6
16,050, Level: 30
Activity: 4.9%
the official site only show AV (composite to scart) and Advanced Scart (RGB) with optical..
I'll check with distributor in the morning and let you know..
Old 11-02-2002, 4:44 PM   #7
Conspicuous Member
dUnKle's Avatar
42,579, Level: 50
Activity: 4.7%
Well I have got the S-Video box coming from the states so I hope very much it works
Old 11-02-2002, 7:00 PM   #8
6,875, Level: 19
Activity: 10.2%
I`ve also ordered one from DVDBoxoffice, Fingers crossed
Cheers Carl
Old 25-02-2002, 10:28 PM   #9
6,875, Level: 19
Activity: 10.2%
Hi Duncan
Just wondering where you ordered your lead from and if it arrived ?
Cheers Carlos
Old 26-02-2002, 9:57 AM   #10
tee tee is offline
tee's Avatar
8,717, Level: 22
Points: 8,717, Level: 22 Points: 8,717, Level: 22 Points: 8,717, Level: 22
Thanks: Gave 0, Got 44
Originally posted by CARLOS
Hi Duncan
Cheers Carlos
I would also like to connect via my amp and this US lead definitely seems like the one to do the trick. Count me in for 'where you ordered from' and 'when it arrives' information
Old 26-02-2002, 5:36 PM   #11
Stewart C
Posts: n/a
Get an RGB to S-Video converter. These work an absolute treat.
You'll need the advanced scart pack though.
Regards
Old 26-02-2002, 7:24 PM   #12
6,875, Level: 19
Activity: 10.2%
Regards
Good idea if a little expensive compared to the Advanced AV pack
Old 10-03-2002, 8:54 AM   #13
Posts: n/a
And also not as good quality as a direct S-Video connection, I've had one of those convertors and although it's convenient I wouldn't recommend it if you want the best image you can get...
Andy
Old 10-03-2002, 8:03 PM   #14
6,875, Level: 19
Activity: 10.2%
My Advanced AV pack arrived yesterday from DVDBoxOffice and only took 4 weeks
Old 11-03-2002, 4:28 PM   #15
tee tee is offline
tee's Avatar
8,717, Level: 22
I ordered at the end of Feb and there's no sign of it being shipped yet
Anyone know where else to get one in time for Thursday?? Is there any sign of a UK version being released on launch day?
Old 29-11-2002, 5:44 PM   #16
bobbles
Posts: n/a
what was in the advanced av pack?
i have bought an xbox and have a Tosh 32ZP18Q TV this has 3 scarts the first being RGB, component inputs and 2 optical inputs
So what do i need to make it DD5.1?
Is it the advanced scart pack with RGB scart and optical lead. It seems a bit steep at 19.99 as I have a spare optical lead but nowhere on the xbox to plug it in.
Or the mentioned advanced AV Pack what exactly is in this pack?
Is the RGB scart really worth it i was going to use a non RGB scart as i am already using the RGB scart input for sky so using it means also buying one of those RGB scart splitter things
I must admit i was shocked the manual didn't even mention how to connect it to DD5.1
Old 29-11-2002, 11:07 PM   #17
6,875, Level: 19
Activity: 10.2%
You need one of the sets of leads to get the optical out which is attached to a break out box !
I think Dixons do a lead pack for about £15 which has optical + RGB scart + S-Video output so you are covered with all connection options
Old 30-11-2002, 12:03 AM   #18
bobbles
Posts: n/a
Is S-Video better than RGB Scart?
What does this sound like from amazon
Xbox Digital AV Cable
JOYTECH
Was: £12.99
Our Price: £9.49
You Save: £3.50 (26%)
Features
AV Scart connector provides and RGB signal and stereo output to your TV
Seperate stereo RCA audio outputs provide connection to your Hi Fi
S-Video output for use with compatible TV's
Optical out to provide crystal clear digital sounds to your digital receiver.
This sounds like what i need
Old 02-12-2002, 2:51 AM   #19
JSW JSW is offline
JSW's Avatar
13,565, Level: 28
Points: 13,565, Level: 28 Points: 13,565, Level: 28 Points: 13,565, Level: 28
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 292, Got 253
http://www.xbreporter.com/xbox_cables_adapters.php
Old 03-12-2002, 11:08 AM   #20
chic's Avatar
16,935, Level: 31
Points: 16,935, Level: 31 Points: 16,935, Level: 31 Points: 16,935, Level: 31
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 153, Got 884
i got hi def kit from game on saturday its a bit steep at £25 but for that you get component conectors , svideo connectors and an optical out and optical cable for 5.1 i have connected the component cables to my ptae and the image is stunning although its not progressive
Old 04-12-2002, 10:23 AM   #21
Laura's Avatar
8,076, Level: 21
Points: 8,076, Level: 21 Points: 8,076, Level: 21 Points: 8,076, Level: 21
Thanks: Gave 18, Got 24
JOYTECH
Was: £12.99
Our Price: £9.49
Thats the one that i've just bought for my soon to arrive XBox. I did a quick deja search and most people thought it was good, though there were supposedly problems with having the S-video and RGB connected simultaneously.
I would say that if you want to buy that one don't get it from Amazon , I originally ordered it from them (Monday) and it has a delivery time of 1-2 weeks. In the end I cancelled the order and bought it from Gameplay instead, costs a little bit more, (13.98 including delivery) but I got it this morning (Thursday)
laura.
Old 08-12-2002, 7:36 PM   #22
Edward Greatrex
Posts: n/a
If anyone is still looking for the Advanced AV Pack or the high definition pack, both are available from MX2, albeit they'd be imports as Microsoft in it's infinite wisdom doesn't consider us worthy to release these over here. Go figure.
MX2 Website
Old 09-12-2002, 11:11 AM   #23
bxd bxd is offline
bxd's Avatar
6,309, Level: 18
Points: 6,309, Level: 18 Points: 6,309, Level: 18 Points: 6,309, Level: 18
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 29, Got 141
There isn't a problem with s-video and rgb... the instructions on the Joytech cable tells you you can't use them both at the same time.
Scart was originally wired for rgb before s-video came along. A scart connector wired for s-video uses some of the pins that were originally intended for rgb, so you can't use s-video and rgb together without interference.
The High Def AV kit has component outputs which aren't too common in the UK. If you have a tv with component inputs then you can use them instead of rgb.
Brian
Old 14-12-2002, 1:39 PM   #24
4,814, Level: 16
Points: 4,814, Level: 16 Points: 4,814, Level: 16 Points: 4,814, Level: 16
Thanks: Gave 4, Got 5
[Deleted by mod]
Old 07-01-2003, 3:09 PM   #25
kevenh's Avatar
7,776, Level: 21
Points: 7,776, Level: 21 Points: 7,776, Level: 21 Points: 7,776, Level: 21
Thanks: Gave 5, Got 0
Originally posted by Laura
I would say that if you want to buy that one {Joytech Digital AV Cable} don't get it from Amazon , I originally ordered it from them (Monday) and it has a delivery time of 1-2 weeks.
I ordered one from amazon yesterday. Like Laura ses they quote 1-2 weeks, but my delivery estimate was 07/01/03 after 30mins.
It's worth waiting 1/2 an hour to get the actual delivery date rather than the 'safe' guess.
P&P is £1.99 extra...
Oh! I'll also try to remember to post a success/fail delivery post!
Old 07-01-2003, 7:47 PM   #26
NeilMcRae's Avatar
7,880, Level: 21
Points: 7,880, Level: 21 Points: 7,880, Level: 21 Points: 7,880, Level: 21
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 2, Got 5
Just remember that with PAL consoles are +not+ supposed to support component video out. Its a bug that is being plugged in new Xboxes and with the Xbox Live upgrade!
Neil.
Old 08-01-2003, 12:04 AM   #27
Laura's Avatar
8,076, Level: 21
kevenh, looks like they've got more in since Christmas.
I put my order in first thing in the morning, and at the 5pm, it was still showing 1-2 wks, and I didn't want it holding up the XBox itself just for an AV lead.
laura.
Old 08-01-2003, 12:21 AM   #28
cbcox
Posts: n/a
Just pop down to Game and get their hi-def pack, £24.99, has s-vid, component vid, photo stereo and optical out. Works a treat with my H50 and home cinema amp
Old 09-01-2003, 10:50 PM   #29
porker's Avatar
4,360, Level: 15
Points: 4,360, Level: 15 Points: 4,360, Level: 15 Points: 4,360, Level: 15
Thanks: Gave 11, Got 3
Ordered my Joytech cable from gameplay 3 o' clock yesterday afternoon and had it hooked up to my system by 9 o'clock this morning!!
Thats what I call service!
£12.99 including standard delivery (2nd class), 99p extra for first class.
Old 10-01-2003, 3:36 PM   #30
kevenh's Avatar
7,776, Level: 21
Amazon sent my cable on time!
Does what it says on the box!
I'm sure the quality of the cabling, etc. will be similar to other high street bundles.
That game one seems over priced - but that opinion isn't based on trials.
I'd like some one like www.lektropaks.co.uk to make us a cable!
