dreamcast on 16:9 TV
Old 23-01-2002, 1:19 PM   #1
Jimmathie
Posts: n/a
Unhappy dreamcast on 16:9 TV
I am thinking of buying a widescreen TV (16:9) would the Sega Dreamcast play alright on the screen or would the games look stretchedbecause it was meant to be view on a 4:3 screen? I have heard that the PS2 and N64 are 4:3 AND 16:9 is this right?
Thanks.
Old 23-01-2002, 1:47 PM   #2
michaelm's Avatar
6,497, Level: 19
Points: 6,497, Level: 19 Points: 6,497, Level: 19 Points: 6,497, Level: 19
When I play some DC games, usually US imports, I usually have to switch my widescreen telly into 16:9 to see the full picture. I don't know if this means the games are widescreen or not.
I can honestly say your enjoyment of DC games on a widescreen tv will not be compromised in any way, unless you use a lightgun with any of your games. If so, do not buy a 100hz set if you are going to use your lightgun with it. It will not work.
Old 23-01-2002, 11:27 PM   #3
GalaxiaN
Posts: n/a
Most Dreamcast games are in 4:3. The only game I have that has a 16:9 mode is Fur Fighters.
You don't have to view 4:3 images streched to 16:9 on a widescreen tv and I prefer to play the games in the mode they were designed to be played. So as long as the black borders left/right don't bother you everything will be fine.
