connecting Mario Kart wirelessly
Old 19-12-2005, 7:07 PM   #1
5,844, Level: 18
Points: 5,844, Level: 18 Points: 5,844, Level: 18 Points: 5,844, Level: 18
Thanks: Gave 0, Got 2
im trying to connect my mario kart game to my by voyager 2000.it asks for my web keys and i typed them in but it doesnt accept them.please please help.thanks
Old 19-12-2005, 7:46 PM   #2
5,844, Level: 18
come on some one there must be able to help me...................
Old 19-12-2005, 8:40 PM   #3
t-force's Avatar
8,477, Level: 22
Points: 8,477, Level: 22 Points: 8,477, Level: 22 Points: 8,477, Level: 22
Thanks: Gave 54, Got 68
What wireless encryption are you using? WPA or WEP?
Old 19-12-2005, 10:47 PM   #4
5,844, Level: 18
wep mate
Old 20-12-2005, 2:48 PM   #5
Maynard
Posts: n/a
Have you checked the Nintendo Wireless router compatability list? To see if the Voyager 2000 is mentioned as having issues with Nintendo WFC?
Old 20-12-2005, 3:42 PM   #6
CrispyXUK's Avatar
11,835, Level: 26
Points: 11,835, Level: 26 Points: 11,835, Level: 26 Points: 11,835, Level: 26
Thanks: Gave 9, Got 26
How long is the encryption?
Old 20-12-2005, 5:50 PM   #7
5,844, Level: 18
it is a 64 bit wep
how do i find the compatability of my router.......where can i find it
Old 20-12-2005, 5:55 PM   #8
5,844, Level: 18
its a bt voyager 2000
Old 21-12-2005, 7:39 AM   #9
Kube's Avatar
13,803, Level: 28
Points: 13,803, Level: 28 Points: 13,803, Level: 28 Points: 13,803, Level: 28
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 379, Got 401
There was a list posted somewhere. Check out http://www.nintendowifi.co.uk
Old 21-12-2005, 5:54 PM   #10
3,808, Level: 14
Points: 3,808, Level: 14 Points: 3,808, Level: 14 Points: 3,808, Level: 14
Thanks: Gave 5, Got 31
Are you broadcasting your SSID? I had mine disabled and it would not find the router, as soon as I enabled it, it picked it up straight away. Unfortunately this is not acceptable for me, so have turned it off, no wireledd mario kart DS gaming for me then!
Old 22-12-2005, 9:44 AM   #11
CrispyXUK's Avatar
11,835, Level: 26
You know you can enter the details manually don't you?
