x2vga
Old 25-03-2005, 5:41 PM   #1
watchinthewheel
Posts: n/a
x2vga
has anyone tried out this gadget with a crt monitor and a pla xbox, according to their site the pal xbox isnt high def enabled but im sure people here have got em working in high def mode, how easy is it to do?
any info is greatly appreciated, thanks.
Old 25-03-2005, 5:58 PM   #2
5,966, Level: 18
Points: 5,966, Level: 18 Points: 5,966, Level: 18 Points: 5,966, Level: 18
Thanks: Gave 10, Got 27
To get a PAL xbox to work in hi-def requires you to mod and switch it over to NTSc anyhow - the X2VGA will NOT work with a PAL box - trust me I've tried it...
Old 27-03-2005, 2:33 PM   #3
watchinthewheel
Posts: n/a
so even if i switch to nstc high def output (which i can do, my xbox is chipped already) it wont work? why surely its the same output as an american or japanese console would give to the x2vga unit?
Old 27-03-2005, 3:40 PM   #4
5,966, Level: 18
Sorry - I obviously mis-understood your point - if using your chip to switch to NTSC then the X2VGA WILL work, but it does need to be set to NTSC.
Old 27-03-2005, 3:54 PM   #5
watchinthewheel
Posts: n/a
excellent! ill be getting an x2vga box asap then, it looks amazing!
