Playstation Connection To TFT Monitor?
Old 17-03-2005, 5:59 PM   #1
5,405, Level: 17
Points: 5,405, Level: 17 Points: 5,405, Level: 17 Points: 5,405, Level: 17
Activity: 5.4%
Activity: 5.4% Activity: 5.4% Activity: 5.4%
Thanks: Gave 3, Got 5
Hi All
I bet this has been asked loads of times,if so apologies.
Is there a way to connect my playstation to my pc tft monitor,if so,it will save me having to buy an LCD TV.
Many Thanks
Alan
Old 18-03-2005, 7:04 PM   #2
Pooon's Avatar
25,795, Level: 39
Points: 25,795, Level: 39 Points: 25,795, Level: 39 Points: 25,795, Level: 39
Thanks: Gave 238, Got 725
Unless the TFT monitor has some sort of video input(unlikely) then you will have to buy a LCD Tv, unless the pc that the monitor is connected to has a video input then it could be possible.
Old 19-03-2005, 6:48 PM   #3
11,799, Level: 26
Points: 11,799, Level: 26 Points: 11,799, Level: 26 Points: 11,799, Level: 26
Thanks: Gave 13, Got 11
You could add a TV card and use the video input on that.
DSCaler is a popular choice as a software solution. The TV card could be one of many cheapo ones (30 quid) and you get very good results. (No scart sockets though, just S-video)
Or you could use a Pro-V tuner box which doesn't need a PC, these cost around 80 pounds.
Old 19-03-2005, 8:31 PM   #4
Greg's Avatar
38,905, Level: 48
Points: 38,905, Level: 48 Points: 38,905, Level: 48 Points: 38,905, Level: 48
Activity: 74.2%
Activity: 74.2% Activity: 74.2% Activity: 74.2%
Thanks: Gave 178, Got 1,395
Yes there is a very easy way.
You need to buy this:
http://www.whitedog.co.uk/catalog/pr...roducts_id=409
You can have it going through your PC, but I just bypassed that and had it going straight to my monitor. Use S-video, as the composite is crap.
