PAL & Hi-Def Kit
Old 06-03-2005, 11:46 AM   #1
5,101, Level: 16
Points: 5,101, Level: 16 Points: 5,101, Level: 16 Points: 5,101, Level: 16
Thanks: Gave 18, Got 25
PAL & Hi-Def Kit
Can i still use the hi-def connection kit if my PAL xbox is not modded?
I plan to mod the xbox in a couple of months (When warranty finishes).
But in the mean time I want to sort out my cabling and I want to use the hi-def to connect my xbox.
Will I still be able to play my games? I know it won't be in hi-def.
Old 06-03-2005, 12:11 PM   #2
cwick's Avatar
7,580, Level: 20
Points: 7,580, Level: 20 Points: 7,580, Level: 20 Points: 7,580, Level: 20
Thanks: Gave 45, Got 98
Yes
Old 06-03-2005, 12:42 PM   #3
5,101, Level: 16
cheers mate.
