PS Two Ixos Scart Cable - Noise??
Old 01-03-2005, 12:04 PM   #1
retro21's Avatar
5,204, Level: 17
Points: 5,204, Level: 17 Points: 5,204, Level: 17 Points: 5,204, Level: 17
Thanks: Gave 11, Got 5
Angry PS Two Ixos Scart Cable - Noise??
Hello everyone.
I recently bought both the Datel Region-X Dvd and an Ixos Scart Cable to improve PQ for both gaming and Dvd playback on a PS Two.
Whilst the Region free works fine and disables the non-RGB playback the Ixos cable has alot of buzzing especially with scenes that have alot of white in them. I am using a normal CRT at the moment.
Its so bad that movies are unwatchable and i've had to go back to a normal scart cable.
Is this a one-off and the cables fault and can i ask for a replacement?
Has anyone else suffered from this experience?
Thank you inadvance.
Old 01-03-2005, 3:19 PM   #2
Illustrious Member
Indiana Jones's Avatar
30,266, Level: 42
Points: 30,266, Level: 42 Points: 30,266, Level: 42 Points: 30,266, Level: 42
Activity: 24.3%
Activity: 24.3% Activity: 24.3% Activity: 24.3%
Thanks: Gave 53, Got 1,273
It does sound like a bad cable, I have always used my old PSX RGB Scart Cable with my PS2 and have had nothing but perfect picture since I got my PS2 all those years ago.
Cant really recommend a cable as mine was just something I picked up years ago from eBay.
Old 01-03-2005, 4:24 PM   #3
retro21's Avatar
5,204, Level: 17
Thank you for the reply.
Guess i'll just return it and stick with the old PSX Scart cable.
Never had a problem with it but always looking for improvements !!
