Install Problem with Xecuter HELP - Red/Green
Old 28-10-2004, 2:37 PM   #1
BoomBoom
Posts: n/a
Cool Install Problem with Xecuter HELP - Red/Green
Hi all,
I have installed my Xecuter 3 into my 1.5 Xbox but am having problems with it. When I power on it reboots twice then says on with the eject button flash red/green the X is red. I can bypass by holding down for 1 second and then it work as a standard Xbox.
Please help. I took it apart and checked all the connections, they look OK but are obviously not totally correct. Can some one point me in the right direction as to what the problem might be?
Thanks,
Boom.
Old 28-10-2004, 3:01 PM   #2
Conspicuous Member
gizlaroc's Avatar
20,250, Level: 34
Points: 20,250, Level: 34 Points: 20,250, Level: 34 Points: 20,250, Level: 34
Activity: 16.3%
Activity: 16.3% Activity: 16.3% Activity: 16.3%
Thanks: Gave 109, Got 391
Silly question but is there a bios on the chip??
Don't know alot about the X3 tbh.
Old 28-10-2004, 3:09 PM   #3
BoomBoom
Posts: n/a
Cool
Yes I think it comes with one basic legal one built in.l
Old 28-10-2004, 3:36 PM   #4
7,884, Level: 21
Points: 7,884, Level: 21 Points: 7,884, Level: 21 Points: 7,884, Level: 21
Thanks: Gave 15, Got 36
Yep it comes with a cromwell bios already loaded. My 1.6 worked first time, however on a 1.5 it's probably the d0 not correctly soldered (so my mate who knows this stuff tells me)
Old 28-10-2004, 3:38 PM   #5
RichMercer
Posts: n/a
Yep, sounds like the d0 to me too. It can be a tricky one to do properly seeing as the solder point is so small!
Old 28-10-2004, 3:58 PM   #6
BoomBoom
Posts: n/a
Cool
Am I right in thinking it could be the d0 OR that I have soldered the other pins incorrectly...or is only going to be d0? I have redone that twice still the same issue...
Old 29-10-2004, 12:17 PM   #7
BoomBoom
Posts: n/a
Cool
sorted it. Not exactly sure what the issue was but resoldered and it was fine.
Boom
