Is there such a thing as this?
Old 19-10-2004, 6:15 PM   #1
Conspicuous Member
Adrenochrome's Avatar
14,131, Level: 28
Points: 14,131, Level: 28 Points: 14,131, Level: 28 Points: 14,131, Level: 28
Thanks: Gave 167, Got 217
I have an X-box that i never use because i cannot get used to the controllers is there a convertor of any kind that would allow me to use a ps2 controller with the X-box?
Adrenochrome.
Old 19-10-2004, 6:18 PM   #2
5,616, Level: 17
Points: 5,616, Level: 17 Points: 5,616, Level: 17 Points: 5,616, Level: 17
Thanks: Gave 5, Got 8
This the sort of thing you are after?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...139292518&rd=1
Old 19-10-2004, 6:21 PM   #3
Conspicuous Member
14,131, Level: 28
Yep that's the chappie
Just need to find a shop that sells them now any ideas?
Adrenochrome.
Old 19-10-2004, 6:43 PM   #4
harrisuk's Avatar
21,025, Level: 35
Points: 21,025, Level: 35 Points: 21,025, Level: 35 Points: 21,025, Level: 35
Thanks: Gave 2, Got 60
Lik Sang sell them as well. You wont have any problems buying from themonline or ebay. Will struggle to find these on the highstreet.
Old 19-10-2004, 6:46 PM   #5
Conspicuous Member
14,131, Level: 28
Not concerned about buying online so long as it is a proper shop.
I have managed to find them here
http://uk.special.reserve.co.uk/q_GG...sx__ps2_p.html
If anyone knows of anywhere cheaper shout up please.
Adrenochrome.
Old 19-10-2004, 6:56 PM   #6
SILVERBACK's Avatar
18,814, Level: 33
Points: 18,814, Level: 33 Points: 18,814, Level: 33 Points: 18,814, Level: 33
Thanks: Gave 136, Got 71
http://www.consoleplus.co.uk/index.p...d0618b22a135de
i ordered from these and have had no probs with mine
Old 19-10-2004, 6:59 PM   #7
Conspicuous Member
14,131, Level: 28
Was it this one here you bought Silver? If it was is it any good?
Adrenochrome.
Old 19-10-2004, 7:08 PM   #8
5,616, Level: 17
http://www.consoleplus.co.uk/product...d0618b22a135de also looks quite good and quite cheap too.... Also the mappings look quite good, whether they are the same on all converters I dont know...
Old 19-10-2004, 7:13 PM   #9
Conspicuous Member
14,131, Level: 28
And it's called the joybox what more does a man want
Adrenochrome.
Old 19-10-2004, 7:50 PM   #10
SILVERBACK's Avatar
18,814, Level: 33
no mate it was the joybox X and it works a treat with pro evo4
Old 19-10-2004, 8:04 PM   #11
5,616, Level: 17
lol - joy in a box - sounds great.....
