Fable, Progressive scan. Problem
Old 19-10-2004, 4:52 PM   #1
jerkyboy
Posts: n/a
Has anyone had any problems running Fable in progressive scan.
I had the UK version first, it runs in 480p but I am getting faint vertical lines covering the entire screen (30" Sharp LCD). I thought that it must be down to the fact that its a Pal game, so I bought the NTSC version and thats the same.
All my other games run perfectly so it must be something to do with Fable.
Any help would be appreciated.
Old 19-10-2004, 5:31 PM   #2
Only777's Avatar
4,169, Level: 15
Points: 4,169, Level: 15 Points: 4,169, Level: 15 Points: 4,169, Level: 15
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 38, Got 7
I've noticed that everything has a slight mesh look to it. As an example, the big blue box logo at the start has small 1cm square boxes inside rather than just solid colour. Or during gameplay the sky will sometimes look like it is filtered thru fishnets or something.
Could be similar to what you're experiencing?
I think it was on the hdtvarcade forums that I read that the newer xboxes didn't do it or that the problem is related to Samsung tv's. But nobody really knew for sure.
Hope this helps.
Old 20-10-2004, 10:10 AM   #3
3,586, Level: 14
Points: 3,586, Level: 14 Points: 3,586, Level: 14 Points: 3,586, Level: 14
Thanks: Gave 24, Got 14
I get faint vertical lines across the image in all 480p games on my xbox/projector setup. Heres a thread about it which unfortunately doesnt contain an answer!
PT AE700E and Pal Xbox (modded) display prob
If you find out anything useful, let me know!
