Joytech sharpshooter2 & KV-32FQ75U
Old 29-04-2004, 8:47 PM   #1
7,587, Level: 20
Points: 7,587, Level: 20 Points: 7,587, Level: 20 Points: 7,587, Level: 20
Thanks: Gave 2, Got 1
I've just purcahsed a Joytech SHarp SHooter 2 which says it works with 100hz. I have a SONY KV-32FQ75U which you can change from 50 to 100 . The gun will not line up at all, it's way off. What am I doing wrong?
Should I have purchased another gun instead?
Old 30-04-2004, 8:27 AM   #2
3,001, Level: 12
Points: 3,001, Level: 12 Points: 3,001, Level: 12 Points: 3,001, Level: 12
Thanks: Gave 2, Got 0
I believe this is the TV I had too and I could get no guns to work on it via any of its settings.
I originally tried the g-con2 which didnt work, so I got a 100Hz compatible gun (the Joytech you have) and that didnt work either.
I dont think there is a lot you can do!
Incidentally my aim would move across the screen horizontally constantly whether I was moving the gun or not.
However the guns worked fine on my friends 28" widescreen TV which was also a Sony!
Old 30-04-2004, 8:36 AM   #3
7,587, Level: 20
oh dear, that's not good news then.
Tony.
Old 30-04-2004, 9:49 AM   #4
Pooon's Avatar
25,795, Level: 39
Points: 25,795, Level: 39 Points: 25,795, Level: 39 Points: 25,795, Level: 39
Thanks: Gave 238, Got 725
i think its something to do with that drc-mf filter that the TV has that prevents you from using a gun, a friend had the same TV but has since replaced it with a Toshiba 32ZD26P which is also 100Hz but that joytech gun works fine on it.
Old 30-04-2004, 9:54 AM   #5
7,587, Level: 20
Can't really justify changing the tv though :-(
Old 30-04-2004, 10:08 AM   #6
CrispyXUK's Avatar
11,835, Level: 26
Points: 11,835, Level: 26 Points: 11,835, Level: 26 Points: 11,835, Level: 26
Thanks: Gave 9, Got 26
Any guns that work with projectors? or is this never going to happen?
Old 30-04-2004, 8:18 PM   #7
Pooon's Avatar
25,795, Level: 39
antonioconte - a bit extreme i know!!!! but my mate had money to burn, plus he's a bit mad.
Don't think guns can work with projectors. What would you point the gun at? the screen or the lens????!!!!!
Old 01-05-2004, 7:10 AM   #8
7,587, Level: 20
I suppose I'd be tempted if I had money to burn though.
