Alternative X-box controllers to controller S?
Old 06-01-2004, 7:34 PM   #1
7,811, Level: 21
Points: 7,811, Level: 21 Points: 7,811, Level: 21 Points: 7,811, Level: 21
Thanks: Gave 2, Got 12
Does any company do an X-box controller with similar layout to controller S but a bit bigger?
Just bought an X-box this weekend, and while the layout of controls is fine, the pad feels a bit small in my hands and I'm not entirely comfortable holding it.
Old 06-01-2004, 11:14 PM   #2
Conspicuous Member
stevegreen's Avatar
30,635, Level: 42
Points: 30,635, Level: 42 Points: 30,635, Level: 42 Points: 30,635, Level: 42
Thanks: Gave 1,182, Got 1,020
If you fancy swapping one of your annoyingly small contollers for an annoyingly large one, then I have a unoficcial second controller thats about a month out of the packing, if you'd like.
Old 06-01-2004, 11:17 PM   #3
Stellavision's Avatar
9,505, Level: 23
Points: 9,505, Level: 23 Points: 9,505, Level: 23 Points: 9,505, Level: 23
Thanks: Gave 4, Got 5
Try Microsofts original controller. The s-type is a smaller version of this, except the two buttons at the bottom right of the pad are on the top right on the original.
Interesting you are not happy with the controller. I discovered on this forum that more console gamers prefer the Xbox s-type controller to any other.
I carried out a survey a little while back. Here is the link
I bought myself an original controller, then I bought an s-type which I discovered was much easier to use.
Old 07-01-2004, 11:11 AM   #4
Azrikam
Posts: n/a
I had always preferred the original, big controller, but I just assumed that I would like the S-controller too if I bothered to give it a go.
Well, during some rather hectic Halo multiplayer gaming over the holidays, I realized that I hate the S-controller. It's not the size or shape that bothers me, it's the size and spacing of the 4 main buttons (A, B, X, Y). With the original controller, I can be touching all 4 buttons with my thumb, for easy access to either of them. With the S-controller, I've either got to hover in the air between presses, or park my thumb in the gap between all the buttons. I found that my reaction time for finding the buttons is much faster on the big controller as my thumb is always touching them, even when not doing anything.
Hope this makes sense. Monster controller for life!
Old 07-01-2004, 5:00 PM   #5
7,811, Level: 21
Maybe most people with an X-box have small hands? Must say I always found the official Playstation joypads too small for real comfort too...
Old 12-01-2004, 6:30 PM   #6
11,048, Level: 25
Points: 11,048, Level: 25 Points: 11,048, Level: 25 Points: 11,048, Level: 25
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Thanks: Gave 271, Got 294
I got my Xbox with a controller S and I love it - it's definitely the best joypad I've ever used.
I haven't used the old style 'big' controller in anger, though I have tried it in shops and I just didn't like it.
Bear in mind that I also like the my Dreamcast controllers which are quite a bit bigger than the S, so it's not just a size thing.
Gav
Old 12-01-2004, 6:32 PM   #7
11,048, Level: 25
Activity: 0.9%
Re: Alternative X-box controllers to controller S?
Logitech do a wireless controller which has a layout like sort of a hybrid between the S and old style controllers.
It's got positive reviews in most places that have reviewed it (example: http://www.maxgameplayer.com/Chong/c...ITECH_XBOX.asp)
I'm tempted to get one myself, but they are pretty expensive.
Gav
Old 14-01-2004, 7:11 PM   #8
supersonic87's Avatar
6,591, Level: 19
Points: 6,591, Level: 19 Points: 6,591, Level: 19 Points: 6,591, Level: 19
Thanks: Gave 0, Got 2
Slightly bigger and wireless pad from lik-sang , work really well.
Rich
Old 16-01-2004, 1:31 PM   #9
i_like_it_cube's Avatar
7,392, Level: 20
Points: 7,392, Level: 20 Points: 7,392, Level: 20 Points: 7,392, Level: 20
I prefer the S controller. We've only had it for a while, not used to it but I'm not even used to the original controller. When my Dad got an XBox, he got an S controller. He hated it so he traded it for an original controller. Now he wants to try it out and bought one on these forums! LOL! Make up your mind Dad!
Old 16-01-2004, 6:35 PM   #10
Garysweb
Posts: n/a
Can you still get the original xbox ones, they are pretty much the same but bigger. Dont get one from game, i got one and they are horrible.....errrrrr
