Go Back   AVForums.com > Gaming > Nintendo Console Gaming
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
DVD sound advice required hansi DVD Players 10 08-03-2009 5:29 PM
720p Vs. 1080p on a 32" TV m_w_clarke Blu-ray Players 6 08-03-2009 1:05 PM
**panasonic Th37pe30 Stand** ismael-1986 Plasma Televisions 0 21-06-2006 2:24 PM
Old 08-03-2009, 2:13 PM   #1 (permalink)
Snes set up on analouge tv no sound issue
i just bought a jvc analouge tv second hand £20 to play my old consoles on.
but when i turn everything on, i dont get any sound from the game, theres just a fuzz noise.
the picture is fine, just no sound, i dont know why?
The snes works fine on my 14 inch portable, but not on this tv, is it worth mentioning that the tv was bought from germany origionally? and wondered if that has out to do with it.
any ideas??
steve
powerbob247 is offline   Reply With Quote
Old 09-03-2009, 3:19 PM   #2 (permalink)
NST
Thanks: Gave 9, Got 48
Re: Snes set up on analouge tv no sound issue
Hi Steve, yes the fact that it's a German TV is the problem. They use PAL B/G over there, which carries the audio on a different frequency (we use PAL-I here).
There's two options (I'll start with the easiest). If the set has a SCART or A/V input, you can purchase the necessary cable(s) for your console(s) and connect it up that way. This will bypass the TV's tuner and you'll get the audio no problem (and a better picture).
The second option relates to changing the audio frequency. If the set is relatively modern (with on-screen display) it may be possible to change the frequency over in a hidden engineers menu (before doing so, check the normal setup menu for any mention of localization/ audio/ tuner options etc).
Try asking for the info and procedure here (quote TV's full model number). If not, then it may not be feasible as it will require hardware modification.
NST is offline   Reply With Quote
Old 09-03-2009, 3:35 PM   #3 (permalink)
I just thought it might thanks for the info very much appreciated!
i just bought a s video composite cable, sold by nintendo on ebay so this should do the job and has a scart with it also. many thanks steve
analouge, issue, nintendo or super, set, snes, snes or famicom, sound, sound off or on
