Go Back   AVForums.com > Gaming > Nintendo Console Gaming
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
S Video Cable is Showing Black/White Picture. martyn@thelongb Interconnects, Speaker Cables and Switches 7 19-06-2006 6:49 PM
S-video - perfect picture but black and white Billilu Satellite TV 10 31-12-2005 2:36 PM
BLack and White picture output from SKY S-Video socket longyp Sky and Sky+ 4 30-12-2005 4:13 PM
Black and White Picture- video sender help pls lard5117 Interconnects, Speaker Cables and Switches 8 17-10-2004 12:23 PM
OT : Scart to S-Video : Black and White Picture HEADRAT Projectors 2 12-09-2002 9:18 PM
Old 09-08-2008, 1:44 PM   #1 (permalink)
Thanks: Gave 10, Got 2
FIXED: N64 + S-Video Cable + LCD TV = Black and White Picture
I have just connected my N64 to my new Samsung LE32A436T via the S-Video connection at the side.
I get a black and white image. I don't believe it is the cable as I used it no problems on my old Hitachi CRT.
Also, I have tried my dreamcast using the S-video output of it's VGA box and I get a full colour picture.
Any suggestions?
Thanks in advance.
Martin
skaterstan is offline   Reply With Quote
Old 09-08-2008, 2:56 PM   #2 (permalink)
Matt_C's Avatar
Thanks: Gave 120, Got 235
Re: N64 + S-Video Cable + LCD TV = Black and White Picture
Whats it plugged into on the TV? A dedicated S-Video input? Or an input that hosts both S-Vid and Composite RCA? Cos if it's the latter, like my TV, you will need to go into the TV menu, to the inputs settings, and you'll be able to select either "S-Video" or "AV" (possibly listed as "composite" or "CvBS") for that particular input number (ie, if it's input number 3)
Samsung PS50A558 | Sony DVP-NS92V | Sony STR-DB870 | Mission M74, MD7S, AS6e | DUAL Freeview PVR | Compaq D510 "Ghetto" HTPC | iPod Video 60gb | iPhone 2G 8GB
Matt_C is online now   Reply With Quote
Old 09-08-2008, 10:21 PM   #3 (permalink)
It has both S-Video and Composite RCA. I did have a quick look at the menu but couldn't see anything that related to it. I'll have a more detailed look tomorrow and post the results!
Old 10-08-2008, 1:51 AM   #4 (permalink)
Matt_C's Avatar
Since it has both on the same input channel, it should have a option for either S-video or composite within the input submenu
Old 12-08-2008, 8:32 AM   #5 (permalink)
Hmm... no luck with that. I had a good look around and couldn't find any menu relating to the input settings for the S-Video port at all.
Tried the S-Video connection from my DVD player and that works fine too. So it must be either the N64 or the cable. Unfortunately I don't have my RF lead with me so I can't check whether it is the N64.
Old 13-08-2008, 2:07 PM   #6 (permalink)
Right, fixed it.
Not entirely sure how it might of been me just ramming the cable in harder, or...
I turned on the N64 then plugged the cable into the TV, it flickered a little bit then produced the colour picture. My guess is it has some auto detect for the settings.
black, cable, lcd, n64, picture, svideo, white
