help linking up computer to wireless
Old 06-12-2008, 6:48 PM   #1
2,687, Level: 12
Points: 2,687, Level: 12 Points: 2,687, Level: 12 Points: 2,687, Level: 12
hi folks
i am connected to broadband using netgear router with virgin broadband, this works fine on my laptop but i want to connect my dads 6 year old computer that doesn't have wireless infaread built in to the broadband
i used a wireless adaptor but it just doesn't get read, the adaptor worked fine on another laptop so i know it aint broke. i also tried linking up to the router using an ethernet cable, it was read by the wireless manager as an adaptor but i still can't connect
could it be something i haven't activated in network or wireless settings??
many thanks
cub
Old 07-12-2008, 11:19 AM   #2
8,156, Level: 21
Points: 8,156, Level: 21 Points: 8,156, Level: 21 Points: 8,156, Level: 21
Activity: 7.2%
Activity: 7.2% Activity: 7.2% Activity: 7.2%
Thanks: Gave 72, Got 546
Re: help linking up computer to wireless
What operating system does it have?
Is it patched up to date.
For example, under windows XP there's a patch you need to apply to make WPA/WPA2 security work. You may also need NIC driver updates - some older ones only support WEP encryption which almost no-one uses these days.
Old 07-12-2008, 5:28 PM   #3
2,687, Level: 12
downloaded xp. where would i get these updates?
thanks michevh
Old 08-12-2008, 10:29 AM   #4
8,156, Level: 21
Activity: 7.2%
Search download dot microsoft dot com for KB893357 or something like XP and WPA2 and I expect you'll find it.
Or you might consider putting on th latest XP servicepack which probably inludes it (and all the upder fixes.)
Powered by
 Latest popular product prices
TP-link 150Mbps High Gain Wirele...
6 prices from
 £8.99 Click to show/hide the offers
6 prices from
TP-link 300Mbps Wireless N USB A...
5 prices from
 £9.87 Click to show/hide the offers
Edimax EW-7811UN
3 prices from
5 prices from
Edimax EW-7811UN
3 prices from
NetGear N150 Wireless USB Adapte...
3 prices from
 £14.99 Click to show/hide the offers
TP-link 300Mbps High Gain Wirele...
4 prices from
 Updated February 11th at 2:30am. Prices include delivery.
