02-12-2008, 1:39 PM
#1 (permalink)
Netgear code
Hi All I have my laptop connected to a netgear router which was installed for me by a friend 10 months ago, I have just recently bought my daughter a notebook for school work and need to get connected to the router. The system is code protected and needs this code to link up but I do not have it nor the friend who did this connection for me can remember what the password is he put in !! is there a way I can find out what the code is so I can link up, or do I have to buy another router and start from scratch ?
Look forword to your help
Best Regards
02-12-2008, 1:53 PM
#2 (permalink)
Thanks: Gave 176, Got 1,225
Re: Netgear code
Try the defaults.
Uername = Admin
Password = Password
You might need to type it twice, I always have to for some reason.
Otherwise I think you can reset to default, but you might have to read up on that.
ASTON VILLA
Never bite the hand that feeds you. It's usually your own.
02-12-2008, 1:55 PM
#3 (permalink)
Thanks: Gave 14, Got 250
Re: Netgear code
You certainly won't have to buy a new router.
Firstly try going into Internet Explorer and typing 192.168.0.1 into the address bar. Go to that address and you should be asked for a password and username. try typing in admin as the username and password as the password ( all lower case). See if that gets you into the router config pages.
If it does then click over "Wireless settings" on the left panel. Towards the botton of that screen you should see Security Encryption, your wireless key should be in there.
If not post back and we can go through re-setting the router to default settings and starting from scratch.
02-12-2008, 2:50 PM
#4 (permalink)
Conspicuous Member
Thanks: Gave 14, Got 447
Re: Netgear code
That was the IP address of my Netgear router, but another one I setup was 192.168.1.1 - if one doesn't work just try the other. If unsure look at the label on the bottom of the router as the IP address will be on there.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
02-12-2008, 4:01 PM
#5 (permalink)
Thanks: Gave 3, Got 346
Re: Netgear code
All the Netgears that I have installed have been 192.168.0.1.
If you don't know the IP Address of a router, do an ipconfig /all. The Default Gateway will be the IP address of the router.
02-12-2008, 4:42 PM
#6 (permalink)
Thanks: Gave 0, Got 7
Re: Netgear code
adsl is 192.168.0.1 cable dsl is 192.168.1.1
a little tip is when you have set your router up get a normal envelope sticker write your new router password and wireless encryption pass word then stick it to the bottom of the router thus never having to worry about finding the piece of paper you wrote the details on
02-12-2008, 4:54 PM
#7 (permalink)
Re: Netgear code
cable dsl ?????
02-12-2008, 5:02 PM
#8 (permalink)
Conspicuous Member
Re: Netgear code
cable DSL as in Virgin Media as your ISP connected via your STB, rather than ADSL via a BT phone line.
Mark.
02-12-2008, 6:07 PM
#9 (permalink)
Re: Netgear code
You mean a Netgear so-called cable router which, as you rightly say, do have 192.168.1.1 as their IP address but cable does not use DSL. DSL (Digital Subscriber Line or Loop) is strictly for telephone lines. Cable uses different technology and Cable routers do not contain it- that is handled by the Cable Modem. In fact Cable Router is a misnomer but it is the name that people use.
03-12-2008, 6:19 PM
#10 (permalink)
Re: Netgear code
Thanks to everyone for your brilliant help on this, will try your advice and any probs let you know.
Best Regards Steve...........
04-12-2008, 7:00 PM
#11 (permalink)
Thanks: Gave 1, Got 4
Re: Netgear code
If you still find from your machine that the you cant access the router it maybe that the default IP address has been changed the easiest way to find this is
Start --> Run --> Type CMD click OK --> In the command window that opens type ipconfig press enter
This should display a default gateway, probably under wireless network settings. Type this address into your web browser and that should do the trick
05-12-2008, 12:14 PM
#12 (permalink)
Re: Netgear code
There's an echo in here.
05-12-2008, 4:51 PM
#13 (permalink)
Thanks: Gave 19, Got 50
Re: Netgear code
Or a different way of achieving the same objective?
TV Panasonic TX-37LZD85 LCD, Amp Cambridge Audio Azur 540R HPTC Silverstone LC17 case, Gigabyte 780G mobo, 2GB Ram, 4850e CPU, LG GGC-H20L Blu-Ray Reader & HD-DVD ROM, 'N' Wireless, Vista 32bit Ultimate. Xbox 360, Wii.
05-12-2008, 5:26 PM
#14 (permalink)
Thanks: Gave 20, Got 6
Re: Netgear code
All routers have a manual reset on the outer casing; it's a small hole with a metal plate. You click it with a pin or something and that will fully reset the router
Jesus can walk on water but Chuck Norris can swim through dry land
Reason: Font tags removed
