Go Back   AVForums.com > Computers > Networking and NAS
Today's price checkPowered by
Microsoft Xbox 360 Wireless Network Adapter (B4B-00018) / IEEE 802.11a/b/g
Belkin F5D8053 USB 2.0 Wireless N Adapter (F5D8053) / 802.11b/g/n
D-Link Xtreme N PCI Express Desktop Adapter DWA-556 / 802.11n/g/b
Dell 1397 Wireless Network Adapter / PCI-E Mini Card (555-11543) IEEE 802.11b/g
Microsoft Xbox 360 Wireless Network A...
Belkin F5D8053 USB 2.0 Wireless N Ada...
D-Link Xtreme N PCI Express Desktop A...
Dell 1397 Wireless Network Adapter / ...
Dell 1510 Wireless Network Adapter / ...
Belkin Wireless High Speed Mode USB A...
Linksys WPC300N Wireless-N Notebook A...
Belkin Wireless G Notebook Card (F5D7...
Dell Wireless 1505 / Mini PCI-E (555-...
NetGear Network Adapter / USB 2.0 (WN...
 More...Prices updated November 24th at 10:30am and include delivery.
Old 28-01-2008, 6:56 PM   #1 (permalink)
Conspicuous Member
recruit's Avatar
Thanks: Gave 427, Got 509
Linksys Wireless 802.11n router and Dell Laptop ???
Hello Chaps,
I'm looking for some advice ref to the above setup which is a new Dell XPS laptop which has the latest Intel Next-Gen Wireless-N Mini-Card installed and the new Linksys WRT150N router, now they work but i cannot get them to work at the extra speed of anywhere near the suggested 300mbs performance all i get is the standard 54meg, am i missing something to get this working right ?
Looking forward to any response
Antec BD HTPC - Oppo BDP 83 - 46" LCD 1080p - Arcam FMJ AV888 - Rotel RMB-1575 - M&K S150THX LCR - M&K CS29's - M&K MX5100SF...
recruit is offline   Reply With Quote
Old 28-01-2008, 7:04 PM   #2 (permalink)
Thanks: Gave 221, Got 174
Re: Linksys Wireless 802.11n router and Dell Laptop ???
If it says 54mbps all the time, it probably means the router is set to G mode in its config.
I'm not very familiar with Linksys routers, but usually there's an IP that you type into your browser to access the router settings. Somewhere in there you might be able to change it to N mode.
Jezzer
EDIT: I think the IP is 192.168.1.1. You could also try 192.168.1.2.
AV: Panny 37LZD80 / Denon 2307 / Optoma EP739 / Panny EX75 / Sky HD / B&W 601s, LM1s & VM1 / 92" Manual / Harmony One
PC: Q6600 / 8800gt / 4gb Corsair XMS / 500gb Spinpoint / Gigabyte P35 / Vista Premium 64bit / PLUSNET BB!
jezzer256 is offline   Reply With Quote
Old 28-01-2008, 7:08 PM   #3 (permalink)
Conspicuous Member
recruit's Avatar
Jezzer
Hi Jezzer, thanks for the response I have been into the settings and tried changeing to N mode only and i completely loose service between the laptop and router, i then have to go back in and change it back to mixed to get it working again
Old 28-01-2008, 7:52 PM   #4 (permalink)
Oh dear, that doesn't sound too good.
The only thing I can think of is that there's several different versions of Draft-N wireless. Maybe youre Dell N card isn't compatible with the router's version of Draft-N. I'm just guessing though.
Jez
Old 28-01-2008, 8:07 PM   #5 (permalink)
Conspicuous Member
recruit's Avatar
Jez
That is what i feared the only other way i can see is to get a USB/Adapter from Linksys but kind of defeats the object of haveing a built in card
Old 28-01-2008, 9:10 PM   #6 (permalink)
Yeah, I would've waited until there's an industry-standard 'N' wireless before buying. What exactly were you hoping to do with your wireless network? 54mbps is fine in most circumstances I find - I can stream 720p over my Netgear G router to my laptop no probs!
Jezzer
Old 28-01-2008, 9:25 PM   #7 (permalink)
Conspicuous Member
recruit's Avatar
yes trying to stream HD content but it struggles with the media i have.
Old 29-01-2008, 8:23 AM   #8 (permalink)
Thanks: Gave 11, Got 62
HD should stream no problems at all over 54mbps wireless ( most of it never goes above 20mbps). What you may be struggling with though is signal strength from the router to laptop. You could try changing channel, or the angle of the aerials on the router, or placing the router higher up etc etc.
Unfortunatly Dell laptops wireless are normally pretty bad, I've had 5/6 dells now and all of them are very bad at wireless. Actually the new D630 I have is the best of the lot but it still struggles at times
My build
cybrey is offline   Reply With Quote
Old 29-01-2008, 10:42 AM   #9 (permalink)
Conspicuous Member
recruit's Avatar
Thanks cybrey, I'll probably just get an external adapter, so is it just the implementation of the Intel N card inside the Dell or a problem with the cards themselves ?
dell, laptop, linksys, router, wireless
