NAS Basics (Data Protection, Performance, Configuration and more)
Old 06-09-2011, 11:35 AM   #61
Eminent Member
HMHB's Avatar
Thanks: Gave 2,906, Got 1,504
Originally Posted by Smurfin View Post
Bit of a contradiction there John - if you want separate drives then by design that's JBOD. Anyone buying a NAS who wants separate drives is better off just buying separate external HDDs in caddies imho.
Surely though JBOD combines the 2 drives to span across and make 1 larger drive doesn't it?
I think you're right though. I probably should just get a single bay NAS.
Old 07-09-2011, 7:18 PM   #62
psikey's Avatar
Thanks: Gave 395, Got 656
Yes you can create two separate drives if you want (with QNAP you can anyway). There effectively two separate volumes but not sure why you would want this with a NAS.
Old 07-09-2011, 7:42 PM   #63
Eminent Member
HMHB's Avatar
That's good to know thanks for that info I looked on the Synology website and from scanning through it I think you can only do this with 1 drive, although I may have misunderstood it !!
I don't want RAID0 as I'd like to have the full space of the 2 drives available to me for storage without increasing the possibility of failure by having them striped.
As I'd be backing up to an external drive off the back of it I can't see the point of RAID1 either. RAID1 doesn't interest me because it's not a proper backup (IMHO).
Old 07-09-2011, 7:54 PM   #64
psikey's Avatar
Similar question covered here: QNAP NAS Community Forum • View topic - hybrid Raid 1 + JBOD
HMHB (07-09-2011)
Old 08-09-2011, 8:21 AM   #65
Limited Member
another site which i've found pretty useful recently helps me save some time while finding and comparing NAS.
Network Attached Storage (NAS)
Network Attached Storage (NAS) Comparison
Old 14-09-2011, 2:58 PM   #66
Thanks: Gave 23, Got 10
I have a question based on this, great bit of information btw. Looking at getting this NAS system: Synology Network Attached Storage - DS211j Products Specifications
Although i may need to look for something cheaper but i'll get to that when i need to.
What i want to know is why should i not rely on RAID 1 for backups? I mean it creates a copy of the HDD so shouldn't that be enough? I don't need a crazy amount of storage so a 2 bay RAID 1 system should be fine for me.
Also what about getting everything to be wireless? Someone in another thread said i would need wires for HD content which i really don't like the idea of. I will be connecting threee laptops, one desktop and potentially 2 TVs with SkyHD on one.
Thanks in advance for any advice you can give.
Old 14-09-2011, 5:51 PM   #67
Eminent Member
HMHB's Avatar
RAID should never be seen as a backup which is why I can't see the point of it! If you accidentally delete a file or a folder on a RAID system then you've lost it completely as it will delete it from the raided drive as well.
Old 21-09-2011, 2:26 AM   #68
Thanks: Gave 2, Got 6
while i understand the point that a mirrored 2 disk NAS is not quite a true backup, it does give me a lot of peace of mind
i got a reduced price netgear stora, and bought an extra 1Tb disk as a mirror. Total cost was about £150. Despite some adverse reviews, I found the Stora totally silent, and very effective
previously i had lots of important files on a couple of PCs. I now check them off the stora, work on them, and check them back in.
yes, we could have a fire etc, but i think i would have other problems if that happened!
Old 26-09-2011, 10:02 AM   #69
Eminent Member
HMHB's Avatar
Does anyone ever run an antivirus scan on their NAS drive? If so, are there any free ones which allow you to scan a network share?
Old 26-09-2011, 10:53 AM   #70
Assured Advertiser
Thanks: Gave 62, Got 216
AVAST free scans network share folders. ( others probably also do the same)
markgrantcables.co.uk --- Highest quality products and service --- Cables, OPPO Blue Ray region free , Focal speakers - Squeeze-upgrade.com PSU- Genuine UK business ( Assured Advertiser)
HMHB (26-09-2011)
Old 26-09-2011, 11:08 AM   #71
Eminent Member
HMHB's Avatar
Cheers. I've had a quick look in my MSE and I can't see an option to scan network drives but will have another look.
Old 30-10-2011, 9:39 PM   #72
mightyken's Avatar
Thanks: Gave 24, Got 17
This clears some things up. Thanks mate!
